unable to access local controller from WLAN
  • 1.  unable to access local controller from WLAN
    Posted Jan 16, 2017 11:19 AM
    equipment:
    2x 7210 master controllers
    2x 7210 local controllers
    aruba 225 AP's
    background:
    I upgraded all controllers from 6.3.x.x-fips to 6.5.0.3-fips.
    After the upgrade i was unable to access the primary local controller from my wireless mangement network. However, I can access both masters and my standby controller.
    What i know:
    -I can not ping/web/ssh to the primary local controller, but i can ping/web/ssh all other controllers.
    -All AP's are up and operational on the primary local controller.
    -any wired device can access all controllers
    -doesnt matter what VLAN or SSID/VAP profile i connect to, same result.
    -User role is authenticated
    -My controller setup is pretty basic, you can safely assume most settings are default
    -i have not added any ACL's
    -statefull firewall settings are all default, or disabled
    I know managing a wireless network wirelessly is a pretty bad idea... but i use it alot for monitoring on my tablet when im out and about away from my desk.
    what im wondering is if in the new OS i upgraded to, for security reasons it blocks someone from managing that device when they are connected through that controller. which would explain why i can reach the other local contoller my ap is not connected to, and the masters, but not the primary my AP's are associated with.
    Either way, whether its a security feature or a bad setting somewhere, I would love to be able to manage that controller from the WLAN again.
    Thanks for your help.
  • 2.  RE: unable to access local controller from WLAN
    Posted Jan 20, 2017 08:13 AM
    Is the controller in question in the same subnet as the other controllers? Is it possibly at a remote site that is not routable with the wireless network?
  • 3.  RE: unable to access local controller from WLAN
    Posted Jan 20, 2017 09:50 AM
    All Controllers are local.
    All local controllers are on vlan 10
    all master controllers are on vlan 20
    the local controllers cannot ping any wireless clients on any vlan.
