Unable to broadcast SSID on 615 AP
  • 1.  Unable to broadcast SSID on 615 AP
    Posted Jan 02, 2024 10:01 AM
    My Access point 615 are on-boarded, However they are not advertising SSID.
    Allowed channel are none on AP.
    AP 2.4GHz and % GHz light are amber.
    kindly guide to fix the issue as allowed channels are none.
  • 2.  RE: Unable to broadcast SSID on 615 AP
    Posted Jan 02, 2024 10:48 AM
    The AP-615 is not supported in Pakistan. Once the AP is supported, there should be a DRT update, the most recent DRT does not even show the AP-615 for Pakistan.
    Best to work with your Aruba partner or local Aruba SE to get more information if support is possible/planned for your country.
