unable to cast to Chromecast under same SSID
  • 1.  unable to cast to Chromecast under same SSID
    Posted Feb 01, 2019 07:45 AM
    So I have read a few posts about this but still unable to get my pixel to cast (or even find the chromecast).. both devices are conected to the same SSID
    I have tried DVLA/airgroup settings (every combintation known to man) but still nothing, if i revert and connect both devices to the SSID from the 'sky router' it works
    Any suggestsions would be welcoming !
  • 2.  RE: unable to cast to Chromecast under same SSID
    Posted Feb 04, 2019 09:24 PM
    What Roles are the client and Chromecast getting and what do the firewall rules look like for those roles?
  • 3.  RE: unable to cast to Chromecast under same SSID
    Posted Feb 05, 2019 04:22 AM
    Hi Thanks for you responce
    I will have to check the roles ( I hadnt touched them so still default)
    There are no firewall rules (just  permit all)
    Cheers
  • 4.  RE: unable to cast to Chromecast under same SSID
    Posted Feb 05, 2019 08:24 AM
    Try disable Airgroup and disable Broadcast filtering in advanced ssid settings.
  • 5.  RE: unable to cast to Chromecast under same SSID
    Posted Feb 05, 2019 11:04 AM
    Hi there, you stated Airgroup/DLNA but there is a specific googlecast extension under these settings which needs to be enabled.
    If you have more or less a default config - this should be all you need to see the cast devices. Outside of this, please let us know what code you're running, ap etc...and portions of the config that are relevant.
    Cheers, Adam
    SE - Service Provider
