Wireless
last person joined: 3 hours ago
Unable to configure dynamic VLAN assignment on IAP
This thread has been viewed 30 times
  • 1.  Unable to configure dynamic VLAN assignment on IAP
    Posted Jun 16, 2023 05:23 AM
    Hi guys,
    I had an SSID using PSK, and now I want to use it with WPA2 Enterprise. I was able to change the Key Management from WPA2 Personal to WPA2 Enterprise, and set the authentication servers. But when I want to change Client VLAN Assignment from Default to Dynamic and click on Apply, the screen returns to Default:
    After clicking on Apply:
    Also I noticed when I want to change the Access from Unrestricted to Role-based I have the same issue, when I click on Apply, the screens returns to Unrestricted:
    Why I have these problems? I have tried creating a new SSID and I still have the same two problems. Please your help.
    Julian
  • 2.  RE: Unable to configure dynamic VLAN assignment on IAP
    Posted Jun 27, 2023 04:19 AM
    Hi guys,
    Any idea?
    Julian
  • 3.  RE: Unable to configure dynamic VLAN assignment on IAP
    Posted Jun 27, 2023 07:49 AM
    If you select dynamic VLAN assignment, you would need to create at least one VLAN Assignment Rule. If you return the VLAN through the RADIUS Aruba-User-VLAN attribute, you can leave this setting to whatever as even with Default (untagged on the AP) or Static (tagged from the AP) the Aruba-User-VLAN attribute will override that configuration. If you need another attribute to set the VLAN, you can do that with a VLAN Assignment Rule (is the VLAN).
    Similar to your Role-based, if you don't have any Role assignments, it bumps back to Unrestricted. You can set Network Based with a basic/locked policy then use the Aruba-User-Role VSA to override that. Or use assignment rules (and I think Aruba-User-Role still overrides that).
  • 4.  RE: Unable to configure dynamic VLAN assignment on IAP
    Posted Jun 27, 2023 05:18 PM
    Hi Herman,
    You are right as always! Within the huge list of attributtes, I didn't realize about the Aruba-User-Vlan attribute, and that I can make a VLAN assignment rule like this:
    Once done, I can configure dynamic VLAN assignment. It is curious because since I couldn't configure dynamic VLAN assignment, I left the VLANs section as Static, and doing tests I realized the VLAN assigned was the VLAN sent from CPPM. And this is as you say, the Aruba-User-Vlan attribute will override this configuration.
    Same for the Access section.
    Thanks a lot!
    Julian
