Unable to connect to SSID on IAP-205 with Windows 10 clients
  • 1.  Unable to connect to SSID on IAP-205 with Windows 10 clients
    Posted Oct 13, 2018 11:59 AM
    I have IAP-205 converted into campus mode mobility based type but the SSID broadcasted i can able to connect with my mobile phones(Android,IOS).But when i try to connect with Windows 10 laptop it was showing "cant connect to this network "
    Any suggestions would be appreciated ?
  • 2.  RE: Unable to connect to SSID on IAP-205 with Windows 10 clients
    Posted Oct 13, 2018 02:33 PM
    How is the SSID configured? What security is being used?
  • 3.  RE: Unable to connect to SSID on IAP-205 with Windows 10 clients
    Posted Oct 13, 2018 02:43 PM
    I configured as SSID with WEP encryption
  • 4.  RE: Unable to connect to SSID on IAP-205 with Windows 10 clients
    Posted Oct 13, 2018 02:54 PM
    I'm not sure how well Windows 10 continues to support WEP since it was deprecated almost 11 years ago. Note that running WEP (or WPA-TKIP) on the IAP-205 will also limit the max speed from 867Mbps to only 54Mbps.
    If possible, I suggest upgrading the SSID to support WPA2 rather than WEP for support and performance reasons.
