Unable to convert a RAP155 with 3200XM
  • 1.  Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 07:31 AM
    Hi Guys,
    One of my RAP5's failed over night so I have got to send a replacement out. I have a spare RAP155 in the office so decided to use this.
    Ive come to convert it but keep getting fails when "Setup VPN" this is not the first 155 I have used so im not sure why this is happening... I have attached the log file.
    Any help would be greatly appreciated!
    Regards
    Anthony
    Attachment(s)
    txt
    rap155_log.txt   9 KB 1 version
  • 2.  RE: Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 07:36 AM
    Tried adding the RAP to the white list to no avail.
  • 3.  RE: Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 08:53 AM
    To convert it make sure you go to the maintenanace TAB , also your controller needs to be using AOS 6.3.0.0 and up to support the RAP155
  • 4.  RE: Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 08:55 AM
    Hi Thanks for your response, but as I mentioned this is not the first RAP155 I have provisioned on this controller and versions are all correct.
    Anthony
  • 5.  RE: Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 09:20 AM
    Do you have enough licenses ?
    Is there a firewall at that locations ? Can you check show datapath session table <IP address> | include 4500
    Make sure you have enough internal IPs in the controller
  • 6.  RE: Unable to convert a RAP155 with 3200XM
    Posted Sep 10, 2014 09:40 AM
    @victorfabian wrote:
    Do you have enough licenses ? Yes
    Is there a firewall at that locations ? Can you check show datapath session table <IP address> | include 4500 No firewall, old RAP5 was working fine.
    Make sure you have enough internal IPs in the controller - Yes loads
    Answers above.
