Unable to Convert IAP-315 to Campus AP
  • 1.  Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 01:36 PM
    We just purchased a few IAP-135's and I need to convert them to campus AP's.  We currently have a 7210 controller running 6.5.4.2.  When I put in the controller's IP address in the AP to do the conversion I get a new tab saying  "Connecting to 10.1.253.11 (My controller IP) failed:  Connection refused.
    Any thoughts\suggestions?
    Brandon
  • 2.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 01:46 PM
    Are you using 135 or 315 , do you have cpsec enabled ?
    Do you have enough licenses ?
    Can you ping the controller from the VLAN the AP is on ?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 01:55 PM
    Hi Victor,
    Sorry, yes it is an IAP-315 "Typo".  I can ping the controllers IP from that VLAN.  This is our first IAP conversion, all of our other AP's are non IAP's.  Also, we have 10 extra licenses.
    Brandon
  • 4.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 01:59 PM
    Do you have cpsec enabled ?
    If you go to the controller CLI you should be able to run the following command “ show log system all | include and see what could be causing this issue
    Thank you
    Victor Fabian
  • 5.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 02:18 PM
    I am not seeing anyting on the controller that would indicate the ap even trying to hit the controller.
    Attachment(s)
    txt
    Info.txt   7 KB 1 version
  • 6.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 02:32 PM
  • 7.  RE: Unable to Convert IAP-315 to Campus AP
    Posted Mar 14, 2018 05:27 PM
    I didn't realize that the code needed to match exactly on the Instant AP as well as the contoller.  As soon as I updated the firmware on the IAP and the converted it everything worked as expected.
