Network Management
Unable to delete device Airwave
  • 1.  Unable to delete device Airwave
    Posted Apr 25, 2019 10:55 AM
    Hi have problem deleting on device in Airwave. I get Scheduled Event is present for this device Sceduled Events.
    How do to remove the event and remove the device?
  • 2.  RE: Unable to delete device Airwave
    Posted Apr 25, 2019 11:31 AM
    If you're the admin, you should be able to cancel out that schedule task from the scheduled events page.  If not, please open a support case so that TAC can provide assistance.
  • 3.  RE: Unable to delete device Airwave
    Posted Apr 26, 2019 02:26 AM
    I'm admin. The problem is that I can't find the schedueled task. Where should it be?
  • 4.  RE: Unable to delete device Airwave
    Posted Apr 26, 2019 06:54 AM
    If you have scheduled config/firmware job, you can delete the event from system>configuration change job or system >firmware upgrade job.
  • 5.  RE: Unable to delete device Airwave
    Posted Apr 26, 2019 07:40 AM
    I have now jobs under system>configuration change job or system >firmware upgrade job.
    I can see a "Configuration change submitted" in Event log but the switch in is offline.
  • 6.  RE: Unable to delete device Airwave
    Posted Apr 26, 2019 08:44 AM
    If switch shows down in airwave after configuraiton push then we need to check switch running configuraiton and last configuraiton recevied from airwave to find why device went offline.
    if you want to delete the device from Airwave then you can do it from APs/Devcies>Manage page.
  • 7.  RE: Unable to delete device Airwave
    Posted May 02, 2019 03:57 AM
    In the above message Sceduled Events. is a hyper link. If you click on that you should be able to see the scheduled events for that device.
  • 8.  RE: Unable to delete device Airwave
    Posted May 02, 2019 07:42 AM
    Put the problem is that there are no jobs under
    Configuration Change Jobs
    Firmware Upgrades Jobs or
    DRT Upgrade Jobs
    it's test switch that I think they have tested running jobs on but the switch have been removed and don't exist any more.
    I have open case to TAC.
  • 9.  RE: Unable to delete device Airwave
    MVP EXPERT
    Posted Jan 16, 2020 10:06 AM
    --- EDIT SOLVED ---
    I change the snmp version in de group folder but hit "Apply" instead of "Apply Save", my bad... :)
    Ever solved? I got the exact same issue.
    • New deployed Airwave 8.2.10.1
    • New deployed Mobility Controllers 8.5.0.5 (MM & 7210)
    • SNMPv3 settings are right in both sides but stay down.
    • Also reboot Airwave server, but didnt solved
    • Exact same issue as you descripted.
    Let me now if you have some information...
  • 10.  RE: Unable to delete device Airwave
    Posted Jan 19, 2020 02:07 PM
    this was in our test environment. If I remember right we contacted TAC and deleted it from the database.
