I am unable to delete network (SSID) profiles since upgrading to 8.2.7.1 on all of my servers. When I click on the delete icon, nothing happens. Using Chrome, I have tried IE as well. Has anyone else experienced this
Hello, we fixed deleting the SSID's on the group level using IGC, from 8.2.8.1, see the release notes capture below:
DE32090:
Symptom: Unable to delete SSIDs over IGC. Scenario:
We now support deleting at the group level in the IGC.
Fayyaz
If you are on 8.2.7.1 you are able to peform this function by moving your pointer slightly to the left of the delete icon and clicking. It will give you the "Do you want to delete...." prompt then
