unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
  • 1.  unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
    Posted Oct 06, 2016 05:07 AM
    hi
    I am installing Airwave 8.2 in existing Aruba infra like 3600 controller with version 5.0.4.15 and 105 Accesspoints but i am unable to discover access points. only i can see the controller in airwave.help me how to add the AP, total 280 Ap are connected to controller.
    Regards
    Aka
  • 2.  RE: unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
  • 3.  RE: unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
    Posted Oct 06, 2016 06:29 AM
    Thanks for your replay
    I fallowd the same document only, I cna see the below messages while installing of Airwave.
    chown: connot access /var/log/ap no such file or directory
    Also i am unable to create groups, when i try to create group it promts me  to contact Aruba TAC.
  • 4.  RE: unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
    Posted Oct 06, 2016 06:31 AM
    Reinstalled Airwave 3 times issue is the same
  • 5.  RE: unable to discover AP 105 in Airwave 8.2, only 3600 controller is discovered using SNMP.
    Posted Oct 06, 2016 01:48 PM
    You should contact TAC.
