Unable to download Aruba 103 latest firmware
  • 1.  Unable to download Aruba 103 latest firmware
    Posted Aug 25, 2021 07:55 AM
    Hi all
    I'm trying to download Pegasus 6.5.4.20 for a 103 while logged in to the support portal
    I see a 'Unable to download file... we will contact to in 2 business days' message but this has been going on for a week?
    Cheers
    Rob
    rob rancans
  • 2.  RE: Unable to download Aruba 103 latest firmware
    Posted Aug 25, 2021 11:50 AM
    Do you have active support on that AP? That is required to download from the support portal.
    You should be able to download the 'factory image' without a contract, and possibly from there, you may be able to use the in-product update to get to a newer release.
  • 3.  RE: Unable to download Aruba 103 latest firmware
    Posted Aug 26, 2021 10:50 AM
    Thanks for the reply.
    No support contract.
    I have 1 standalone test unit that upgraded itself to the latest firmware after a factory reset. I will try the same with the 2 units that are in constant use for WFH to see if they also bring themselves up to date.
    Cheers
    Rob
    rob rancans
  • 4.  RE: Unable to download Aruba 103 latest firmware
    Posted Sep 16, 2021 11:40 AM
    I can confirm that factory resetting all APs and reconfiguring the first triggered a firmware upgrade to the latest version. APs joined subsequently also updated successfully.
    rob rancans
