Unable to edit WLANS
  • 1.  Unable to edit WLANS
    Posted Sep 06, 2012 07:19 AM
    Hi, I'm getting this message and can't find how to resolve this issue:
    Kendal-Guest has been modified such that it is no longer editable from
    this Wizard. REASON: Unknown role Kendal-Guest-guest-logon (No
    PEF).
    Use the full Configuration user interface to edit it.
    Where is this full configuration? Thanks
  • 2.  RE: Unable to edit WLANS
    Posted Sep 06, 2012 10:44 AM
    can you post the output of the command
    "show license"
    It looks like your PEF license expired or got deleted somehow.
  • 3.  RE: Unable to edit WLANS
    Posted Sep 06, 2012 11:45 AM
    He must be trying to use the wizard with Firefox 14....
    Try using Internet explorer and that issue should be gone...
  • 4.  RE: Unable to edit WLANS
    Posted Sep 06, 2012 01:25 PM
    I've been using IE. Thanks
  • 5.  RE: Unable to edit WLANS
    Posted Sep 06, 2012 01:27 PM
    Okay i mention it because there is a bug with Firefox 14 in which it will show you a similar message
  • 6.  RE: Unable to edit WLANS
    interstingly enough, my license doesn't show up. I will have to add it back and see what happens. I have been configuring a 3400 and copied the config from my 3200. Thanks
