Wired Intelligent Edge
Unable to form tunneled-node tunnel to Central managed controller
  • 1.  Unable to form tunneled-node tunnel to Central managed controller
    Posted Apr 26, 2020 08:53 AM
    Trying to do user based tunneling from 2930F directly connected to a Central managed 9004. I'm able to ping the 9004's controller IP and ssh to it from the 2930F, but when I set the IP as controller IP I'm only getting this in the 2930F debug:
    0010:02:00:29.44 TNT mtnodeUserCtrl:UserTNode: Info: Special Bootstrap request is sent to 10.133.102.130
    2930F is left in "In Progress" state after that and nothing happens. If I try to use the LAN IP address of the controller it goes further to form a tunnel but then complains that the LAN IP is not the controller IP.
    2930F is assigned a role that has allowall policy in it.
    Any ideas?
  • 2.  RE: Unable to form tunneled-node tunnel to Central managed controller
    Posted Apr 28, 2020 07:25 PM
    Can you share a sanitized switch config and the output of "show tunneled-node-server state"?
  • 3.  RE: Unable to form tunneled-node tunnel to Central managed controller
    Posted Apr 29, 2020 03:34 AM
    State was "In Progress". I did a wireshark capture from the switch and seems that the gateway always responded with it's LAN IP address. I had configured 10.30.24.3 on the LAN interface gi0/0/2, (VRRP with .1) and my system IP was 10.30.65.1 on VLAN 3365 (which was forced up)
    I could see that whenever I tried to form the connection to any of the controller's IP address, the controller responded from IP 10.30.24.3
    I upgraded the software to an "early release" version of 8.5.0.0-2.0.0.4_75023, then booted the gw obviously. Not sure whether the firmware upgrade helped, but after that the controller started to respond with 10.30.65.1. So it's working now.
