Unable to get aruba 2540 switches in aruba central
This thread has been viewed 44 times
  • 1.  Unable to get aruba 2540 switches in aruba central
    Posted Feb 22, 2017 05:43 AM
    Hi All,
    Im facing a little problem.
    I try to get the 2540 into our aruba central account.
    Things that i did:
    show activate provision
     Configuration and Status - Activate Provision Service
      Activate Provision Service   : Enabled
      Activate Server Address      : device.arubanetworks.com
      Activation Key               : Not Available
    The activation key is not shown. This is a indication that it cannot reach aruba activate?
    also:
    # aruba-central enable
    # show aruba-central
    Configuration and Status - Aruba Central
      Server URL       : None
      Connected         : No
      Mode                 : NA
      Last Disconnect Time : NA
    The DNS is set and i can ping:
    ping device.arubanetworks.com
    device.arubanetworks.com is alive, time = 146 ms
    From this network i also tryed to get a IAP into central. This is no problem and works right away.
    I also tryed to add the switches to central using the SN and MAC. I also assigned a subscription key.
    I have requested a activate account but it takes a few days to get this account approved.
    Tested both with 16.2 and 16.3 firmware.
    Someone knows a solution?
    #2540
  • 2.  RE: Unable to get aruba 2540 switches in aruba central
    Posted Mar 16, 2017 04:15 AM
    Seems that the switch needs to be factory default. When in central, it looks like you can only configure it from the central gui and not use the CLI.
  • 3.  RE: Unable to get aruba 2540 switches in aruba central
    Posted Feb 22, 2022 05:10 PM
    Any idea of how to get the switches to show up as Online in Central without performing a Factory Reset.  Trying to add a 3810 and several 2920 switches so we can see how the monitoring works before reconfiguring all of our switches.  The firmware levels are above the minimum required however on all of them a show aruba-central command results with None, No and NAs as the results.  Can ping arubanetworks.com, however device.arubanetworks.com doesn't return a result.
    Thank you for any insight that can be provided.
    Jason Boyd
  • 4.  RE: Unable to get aruba 2540 switches in aruba central
    Posted Nov 29, 2018 03:51 AM
    Hi
    I have had the same issue with my Aruba 2530.
    what I worked out eventually was a way to force the switch to reconnect to Aruba Central
    I used the following commands:
    activate provision enable
    activate provision force
    This then gave me the activation key
    And when I ran the following command
    show aruba-central
    I was presented with
    Server URL               : https://device-eu.central.arubanetworks.com/ws
    Connected                  : Yes
    Mode                         : Monitor
    Hope this helps.
