For multiple AP models to be part of the same Instant cluster, all APs should run the same firmware version. From the WLAN platform matrix (or other information sources), you can see that the AP 500 series need Instant 8.6 or newer. You should upgrade the existing cluster to a common shared version for the 305 and 505, where 8.10 (LSR) would be a good version if you don't need the latest features.
Original Message:
Sent: Aug 15, 2024 04:59 AM
Subject: unable to join AP 505 with the 305 Virtual controller 6.5.4.4
I'm unable to join two new AP 505 aps to the virtual controller. Auto Join is already enable. The IP also been add and same segment with current AP.
My current environment I have 11 Aruba AP's 305 and one is a victual controller, the AP's are attached to poe switches.
Any help would be greatly appreciated
Thank you
