Unable to join AP to cluster/master
  • 1.  Unable to join AP to cluster/master
    Posted Nov 23, 2016 09:00 AM
    I am trying to deploy 3 AP-205. I have set one up successfully, but unable to adde the two other to the network/cluster.
    When I connect the AP it boots up, but both the 2,4Ghz and 5Ghz light stays amber. It does not join the the master AP in building a cluster.
    They are connected to a switch whose ports are configured with the following VLAN-setup:
    ports 3-6: vlan 10 untagged, vlan 20 tagged
    I have a suspicion it is the vlan-setup that is causing problmes...
    I have attached the config-file and ap-log from the running AP (master).
    It looks as if the second AP does *something*, because I am not able to log into the instant-ui with the standard password, and it does not set up the "instant"-wifi-network
    Attachment(s)
    txt
    aplog-system.txt   491 KB 1 version
    txt
    techsupport-dump.txt   491 KB 1 version
  • 2.  RE: Unable to join AP to cluster/master
    Posted Nov 23, 2016 09:12 AM
    We need the "show log system" from the APs that are not booting up to understand what could be going wrong.
