Unable to log into GUI for CPPM 6.3
  • 1.  Unable to log into GUI for CPPM 6.3
    Posted Aug 29, 2014 06:14 PM
    So, I just finished setting up our 6.3 install of CPPM. License is in, copy is validated, but I cannot log in via the GUI. The local CLI login for appadmin works just fine. Is there an additional account for the GUI login? Not sure what the issue is.
  • 2.  RE: Unable to log into GUI for CPPM 6.3
    Posted Aug 29, 2014 06:17 PM
    admin / eTIPS123
  • 3.  RE: Unable to log into GUI for CPPM 6.3
    Good timing, cappalli! Haha.
  • 4.  RE: Unable to log into GUI for CPPM 6.3
    Posted Sep 02, 2014 02:24 PM
    Hello Josh, thank you for letting us know the User Guide is a little confusing--one of our experienced Principal Technical Writers will be reviewing it and making corrections where necessary to make it more clear.
    Thank you again,
  • 5.  RE: Unable to log into GUI for CPPM 6.3
    Posted Sep 02, 2014 02:29 PM
    Thanks, Ostrowski! I appreciate the consideration. I think just adding some notes on the different accounts and what they're used for would be immensely helpful. Take care. :D
  • 6.  RE: Unable to log into GUI for CPPM 6.3
    Nevermind, figured it out. It appears there is appadmin for CLI and admin for GUI. Very confusing, since I don't see this mentioned in the user guide document.
    Here's a link to the info I found: http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Default-CPPM-user-accounts-to-access-CLI-GUI-and-database/ta-p/179666
