Unable to login to CP Guest with Operator account
  • 1.  Unable to login to CP Guest with Operator account
    Posted Jun 03, 2014 08:57 AM
    I am unable to login to CP Guest with an operator account.  Fails with incorrect username or password error.
    The operator account is not LDAP.
    Any help/suggestions would be recommended, or if anyone has any specific examples of the Mapping Rules for an operator login, I would be grateful.
    Thanks.
  • 2.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 03, 2014 09:04 AM
    Did you create a TACACS enforcement profile that returns the role name to ClearPass guest?
  • 3.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 03, 2014 09:18 AM
    I didn't have any Enforcement Profiles set.
    I have tried the TACACS template you have suggested; but this is still failing - under the Enforcement Profile options for Service Attributesthere is no Engineering profile listed - just Super Admin downto API Admin (don;t know if that indicates anything in particular that is wrong).
    I've tried applying the default Receptionist role to the user that I created - to try and isolate what is not working; and this still failsw ith same error.
  • 4.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 03, 2014 11:56 PM
    What is the error you are getting?
  • 5.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 04, 2014 04:04 AM
    The process that I am trying to follow to login to Clearpass Guest is to connect to https://<ip address>/tips/welcome.action
    This then presents me with CPPM, CP Guest, CP OnB+W and CP Insight.
    If I select the CP Guest option and try to login using the OPERATOR LOGIN form, I get Invalid Username or Password
    I have now realised that I have the same problem with the admin account on Clearpass.
    If I login to CPPM as admin and then launch CPG I do not get prompted for a username\password and get logged in - I have been doing this without error (through sheer luck).
    If I try and launch CPG from the welcome.action form (and not login to CPPM first) I get the same problem as with the operator accounts I have tried to setup.
  • 6.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 04, 2014 04:07 AM
    Is there an error in access tracker when you try to log in?
  • 7.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 04, 2014 04:50 AM
    Yep, there is an entry in Access Tracker log
    Error Code:          204
    Error Category:   Authentication failure
    Error Message:  Failed to classify request to service
  • 8.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 04, 2014 04:53 AM
    It means that you either don't have a service defined or it's been disabled or deleted.
    There should be one in there by default for guest operator.
  • 9.  RE: Unable to login to CP Guest with Operator account
    Posted Jun 04, 2014 05:53 AM
    All problems, for Operator and admin have been resolved.
    Navigated to CPPM > Configuration > Services and then need to enable both (not one) of the following:
    Policy Manager Admin Network Login Service           Type=TACACS
    Guest Operator Logins                                                   Type=Application
    Many thanks for all input into investigating this problem.
