unable to provision ap 65's
  • 1.  unable to provision ap 65's
    Posted Jun 25, 2015 08:07 AM
    Hi all,  new controllers running a mixture of AP65's 70's 105's all good.   Trying to provision unused, out of box 65's without success, any ideas ??  I dont have a SOE adapter so cant see the boot process, new 105's no problem....
    Cheers
  • 2.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 08:09 AM
    What version of ArubaOS? We're those access points used before?
  • 3.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 08:11 AM
    Colin, believe it or not they are new/unused,  version 6.3, have maybe a couple of hundred 65's that were on old controller, just the new ones I cant see...
  • 4.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 08:15 AM
    If the AP65s were not used, they need to first be connected to a controller on the latest 5.x, before being connected to 6.x. New Aruba 65s had a limit on the size of the image they could download and the newest 5.x corrects this.
  • 5.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 09:25 AM
    Colin, your a star, luckily had the old controller to hook them upto, many thanks.
  • 6.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 10:04 AM
    Hi Colin, was all looking good as they came up on old controller, connected to new and they still seem to be recycling ?  any ideas ??
  • 7.  RE: unable to provision ap 65's
    Posted Jun 25, 2015 10:35 AM
    With the 65 on the 5.x controller, you may need to do an apflash all backup-partition.
    Take a look at the command in the CLI guide.
  • 8.  RE: unable to provision ap 65's
  • 9.  RE: unable to provision ap 65's
    Posted Jun 26, 2015 07:00 AM
    Thanks for all the help, turns out the 65's would not get a LAN provided DHCP address ??  had to manually assign using an old controller, connect to new controller, let 65's flash 6.3 code then change back to DHCP and all good.
    Very bizzare.
