unable to provision AP from GUI
  • 1.  unable to provision AP from GUI
    Posted Jan 17, 2012 04:11 AM
    I cannot provision one of my ap, when i click provision, it is returning an error message
    Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3; .NET4.0C; .NET4.0E)
    Timestamp: Tue, 17 Jan 2012 08:57:37 UTC
    Message: 'this.apparams.apgroup' is null or not an object
    Line: 2536
    Char: 1
    Code: 0
    URI: https://xxx/jscripts/approvision.js
    This only happen to one particular AP, the rest is working fine
  • 2.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 04:14 AM
    What version of ArubaOS is this?  What type of AP is it?
  • 3.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 04:17 AM
    i am using os 6.1.2.0 and ap 125
  • 4.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 04:21 AM
    Can you try first clearing your browser cache?  Is there any way that you can upgrade to the latest 6.1.x , as well?
  • 5.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 04:27 AM
    i do not think that is a browser issue as i am trying from different computer, from firefox and google chrome, it do not show any error message but the page that show up is blank after i click provision. i will consider upgrading to the latest version and give it a try again. However, i remember that i was able to provision this AP 2 weeks ago and when i want to reprovision it again today, it is not working
  • 6.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 09:21 AM
    Is there a space in the AP name?
  • 7.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 11:57 AM
    I'm having the same issue. And I tried clearing the cache and same results... BLANK Page, no error. And to the AP-Name.... Yes, the 3 APs that I'm having provisioning issues with have spaces in the name. The other APs I provisioned did not. How do I fix the problem then?
  • 8.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 12:09 PM
    on the command line.....
    #conf t
    #ap-rename <serial number of ap> <new ap name>
    #write mem
    That should do the trick.
  • 9.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 05:23 PM
    (aruba) (config) #ap-name <SerialNumber> <Name_XXXX-YYYY_ZZZZ>
    % Invalid input detected at '^' marker.
    The trick didn't work. I got the above error. Any thoughts?
  • 10.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 06:35 PM
    Did you try it without the <> around the serial and new ap name?
  • 11.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 06:44 PM
    Yes, for example....
    (aruba) (config) #ap-name AJ0288555 Name_XXXX-YYYY_ZZZZ
    Above is what it looked like.
  • 12.  RE: unable to provision AP from GUI
    Posted Jan 17, 2012 06:51 PM
    Try ap-rename not ap-name
  • 13.  RE: unable to provision AP from GUI
    Posted Jan 18, 2012 09:30 AM
    there is the spacing in between and i guess that is the reason that it is not working as the rest of my ap is without spacing. Also i tried the ap-rename command that getting the same error as tecniq
  • 14.  RE: unable to provision AP from GUI
    Posted Feb 27, 2012 02:25 PM
    Sorry, missed the 2nd page, saw after I posted.
  • 15.  RE: unable to provision AP from GUI
    Posted Jan 18, 2012 09:35 AM
    use quotes around the ap name with spaces.
  • 16.  RE: unable to provision AP from GUI
    Posted Jan 18, 2012 10:20 AM
    thanks it is working and i can now provision the ap from GUI.
    The actual command shall be (Aruba3400) (config) #ap-rename serial-num xxxxxxxxx "xxxxxxx"
  • 17.  RE: unable to provision AP from GUI
    Posted Jan 18, 2012 11:11 AM
    Thanks people. This worked for me too.
  • 18.  RE: unable to provision AP from GUI
    Posted Feb 21, 2012 06:28 AM
    Thanks for this post. Help me with my issue as well.
  • 19.  RE: unable to provision AP from GUI
    Posted Feb 23, 2012 05:13 PM
    If possible, please mark this post as solved. Appreciate it.
  • 20.  RE: unable to provision AP from GUI
    Posted Feb 27, 2012 12:25 PM
    This issue is fixed in version 6.1.3.0
    I know this because i reported the issue to Aruba :)
    While working with techsupport we discovered it was because of the spaces in the name and they worked the fixed into the next release.
