unable to push AP group attribute from Aruba Activate for one AP
  • 1.  unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 08:33 AM
    Hi Team,
    We have converted the IAP to CAP and AP shows in the MD but it comes up in default ap-group. But we have mentioned a different AP-group in the provisioning rule and the same is present in the MD [8.6].
    Thank you in advance!
  • 2.  RE: unable to push AP group attribute from Aruba Activate for one AP
    MVP GURU
    Posted May 20, 2020 09:17 AM
    Can you share the provisioning rule? You can also use an AP whitelist to put the AP in the correct group.
  • 3.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 09:22 AM
    Thank you for your response. the rule is as below:
    Rule Type: Provisioning Rule
    Parent Folder: ABC
    Provisioning Type: IAP to CAP (controller)
    AP Group: test
    controller: MD IP
    Persist Controller IP : Checked
    Rule name: IAP to CAP
    Create date: Today
    Created by: XX.
    CPsec disabled.
    Thank you!
  • 4.  RE: unable to push AP group attribute from Aruba Activate for one AP
    MVP GURU
    Posted May 20, 2020 09:28 AM
    I'm not 100% sure, but you might have to import the Activate AP whitelist into the controller. You can have automatic whitelist sync set up between the controller and Aruba activate. I'm not able to get into my lab to check right now, but maybe you could try that?
  • 5.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 09:41 AM
    Thank you for the update.
    Do we have to use "import the Activate AP whitelist into the controller" even when CPsec disabled?
  • 6.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 09:55 AM
    AP-Group assignment is not supported , when using IAP to CAP provisioning rule
    You can create a ap provisioning rule in the controller , that can dynamically place Aps in the desired AP-Group based on the following conditions: ap-type , ip-range, network
    https://www.arubanetworks.com/techdocs/ArubaOS_84_Web_Help/content/arubaframestyles/1commandlist/ap_provisioning-rule.htm
    Sent from Mail for Windows 10
  • 7.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 10:42 AM
    Thank you so much for your response. AP-Group assignment is not supported , when using IAP to CAP provisioning rule : do we have any document which updates the same so i can share it with end user.
    Thank you!
  • 8.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 11:02 AM
    Here you go:
  • 9.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 11:16 AM
    Spoiler
    Hi Victor,
    Thank you for your response. But end user is able to map the ap-group in the rule.
    Thank you!
  • 10.  RE: unable to push AP group attribute from Aruba Activate for one AP
    Posted May 20, 2020 11:17 AM
    Hi Victor,
    Thank you!
