Unable To Restore CPPM backup
This thread has been viewed 36 times
  • 1.  Unable To Restore CPPM backup
    Posted 14 days ago
    Hi all, im facing issue while restoring db backup of existing clearpass v6.9.13 to new clearpass v6.11.1
    Both of them are hardware appliances
    Pls find the error screenshot attached
    Any suggestions are much appreciated
  • 2.  RE: Unable To Restore CPPM backup
    Posted 13 days ago
    generally i woul dtry to resote the backup to the latest version of 6.11 which is 6.11.4, see if that makes a difference
  • 3.  RE: Unable To Restore CPPM backup
    Posted 13 days ago
    Hi aryap, thanks for your response, will try and let you know
  • 4.  RE: Unable To Restore CPPM backup
    MVP
    Posted 10 days ago
    Even when you migrate, from 6.9 or 6.10 to 6.11 Clearpass requires fresh install with some migration guides which usually support provides as recommendation.
    Did you check with support team and the guidelines process?
    Shpat | ACEP | ACMP | ACCP | ACDP |
    -Just an Aruba enthusiast and contributor by cases-
  • 5.  RE: Unable To Restore CPPM backup
    Posted 10 days ago
    Yes actually i just done this fresh installation on new boxes
    But my licenses are yet to activate, is it because of this my db unable to restore ?
  • 6.  RE: Unable To Restore CPPM backup
    Posted 9 days ago
    I found a similar case with a similar message and there license activation resolved the issue.
    So first activate the license, then restore the database.
  • 7.  RE: Unable To Restore CPPM backup
    MVP
    Posted 6 days ago
    Had a similar case.
    When licenses were activated, issue was solved.
    What you can do is that you can try with Trial Licenses maybe and see if it works (so you don't have to wait till other licenses will be activated/sent).
  • 8.  RE: Unable To Restore CPPM backup
    Posted 5 days ago
    Yes as per you told post license activation and valid certificate import, restored db successfully.
  • 9.  RE: Unable To Restore CPPM backup
    MVP EXPERT
    Posted 10 days ago
    I tend to try and get as close to the new release as possible and have successfully uploaded config from 6.10.8 -> 6.11.1 & 6.11.4
    Have you tried spinning up a temp vm running 6.10 and importing into that then exporting and using result on 6.11?
    Not activating your keys won’t be an issue
    A
    Sent from my iPhone
