unable to restore running configuration
  • 1.  unable to restore running configuration
    Posted Jan 20, 2012 05:17 AM
    Hi Forum,
    I want to restore only running configuration to replace existing configuration. I successfully transferred Running Config. file from TFTP to Flash file system now how can i replace my current running config with my transferred running configuration file, all other configuration must be remains same.
    Faisal
  • 2.  RE: unable to restore running configuration
    Posted Jan 20, 2012 05:24 AM
    Under Maintenence> Controller > Boot Parameters, you can select which file is selected after the reboot.
