last person joined: 5 hours ago
Unable to SSH after installing PEFNG license
  • 1.  Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 02:47 PM
    Hello All,
    After using and commissioning Aruba boxes for some time now I have today encountered a new problem for the first time.  A quick search of these forums and the Internet reveals no instant answer.
    The scenario is that I unbox a new controller, complete the setup wizard then apply IP settings so I can access the device through SSH over our staging network.  This works fine, as expected.  The problem comes in the next step of the commissioning process where I add the license - once the PEFNG license is installed, I can no longer SSH to the box.  Indeed, the GUI is broken too.
    This is on 3400 controllers with OS 5.0.4.0.
    I expect it is a trivial aspect of the config we are using the new PEFNG licenses and 5.0.4.0  for the first time.
    Has anyone else come across this or know how to resolve the issue?
    Regards
    #3400
  • 2.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 02:49 PM
    Did you reboot after you added the license?
    Make sure the port you are coming in on is trusted.
  • 3.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 02:56 PM
    Hi -  yes, the device has been rebooted several time - as it took a while to work out it was the PEFNG lisence causing the issue.
    All vlans are trusted on all ports, to be on the (not) safe side.
    I've also tried data path in as VLAN 1, not vlan 1, untagged and tagged... this seems to make no difference.  I have a bunch of these devices all manifesting the same behaviour.
    Surely it's something frustratingly simple?  (yes, I've raised a TAC - #1279848)
    Thanks for your help
    A
  • 4.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 03:03 PM
    Did you try consoling into the device?  Can you you ping your default gateway when you do that.?
  • 5.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 03:17 PM
    yep - console works fine, so I can ping:
    from controler to default gateway
    from laptop to controller
    from core switches to controller and back
    There have been no changes ot this network for some time.
    Thanks again
  • 6.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 03:33 PM
    Does the cotroller have any port channels?
  • 7.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 09, 2012 03:37 PM
    I don't believe so, - I haven't configured any.  What's a good command to check?
    A
  • 8.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 10, 2012 08:56 AM
    A
    If you have not configured any, you don't have any.  Please continue to work with support, since a reboot didn't fix it.
  • 9.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 22, 2012 01:13 PM
    can you try the following commands,
    show user  |  in  <ip address of device from where you are trying to SSH>
    show datapath session table <ip address of device from where you are trying to SSH>
  • 10.  RE: Unable to SSH after installing PEFNG license
    Posted Feb 23, 2012 08:39 PM
    Can you also run "show ip access-list validuser" and paste the output here?
