Unable to sync configuration with members:
  • 1.  Unable to sync configuration with members:
    Posted Aug 18, 2014 10:53 AM
    Working on a stack of three Aruba S2500-48P-4x10GB PoE, they have been working fine for the last 10 months.  Made a simple change to the config, went to save the config and get this message:
    Saving Configuration............................................................................................................................................................................
     Unable to sync configuration with members: 1
     Write memory command failed. Please try again !!
    Has anyone else ran across this?  Unfortuantely I'm not in an environment where we can simply reboot and see if the problem goes away.
  • 2.  RE: Unable to sync configuration with members:
    Posted Aug 18, 2014 10:55 AM
    What version of code? This was a known bug in a 7.2.x release.
  • 3.  RE: Unable to sync configuration with members:
    Posted Aug 18, 2014 10:57 AM
    They're running Version 7.1.3.2
  • 4.  RE: Unable to sync configuration with members:
    Posted Aug 18, 2014 10:59 AM
    Yes, this issue was seen in images prior to 7.2.2.2. Here's the description of the issue from the release notes.
    Symptom: Executing the write memory command on a standalone Mobility Access Switch or an ArubaStack was periodically failing with the following error message:
    Additionally, the show image version command also stopped displaying details properly. Upgrading to ArubaOS 7.2.2.2 resolves this issue.
    Scenario: This issue occurred when the file system incorrectly became read-only. This was not limited to any specific Mobility Access Switch model.
  • 5.  RE: Unable to sync configuration with members:
    Posted Aug 18, 2014 11:00 AM
    That code is from early 2012 and likely has this bug. Temporary solution is to reboot. You should plan to upgrade your code.
  • 6.  RE: Unable to sync configuration with members:
    Posted Feb 27, 2015 08:42 PM
    cappalli - You mentioned rebooting as a temporary solution.  If you do that will any config changes that took place since the last write mem be preserved?  If not, will you be able to change the configuration after the reboot and then perform a write mem?
  • 7.  RE: Unable to sync configuration with members:
    Posted Apr 10, 2015 05:30 PM
    I confirmed. When it is in this state nothing gets saved as the error message indicates. A reboot will allow you to save the configuration.
