unable to upgrade 6.5.4.12
  • 1.  unable to upgrade 6.5.4.12
    Posted Jul 15, 2020 02:51 PM
    trying to upgrade from 6.5.4.12 to 8.6 also tried 6.5.4.16
    it keeps failling and i cann find in the log why
    we did push a batch of config changes, but i cannot figure out why it wont upgrade. are there any configs that stop this upgrade i need to remove?
    been pulling my hair out for 2 weeks now, time to ask for help
    we use airwave to manage and upgrade
  • 2.  RE: unable to upgrade 6.5.4.12
    Posted Jul 15, 2020 02:52 PM
    What method are you using?
    Is this a controller-based install or Aruba Instant?
  • 3.  RE: unable to upgrade 6.5.4.12
    Posted Jul 16, 2020 04:24 AM
    As Colin mentioned, it's important to understand if this is Instant or a controller deployment as the approach will be different. For controller you need to migrate your configuration and can't just upgrade the firmware between 6.x and 8.x.
    Have you tried to do a manual upgrade of one of your devices outside of Airwave? That may indicate why an upgrade in Airwave does not work properly.
    If you don't want to spend too much time on this, please reach out to Aruba Support.
  • 4.  RE: unable to upgrade 6.5.4.12
    Posted Jul 16, 2020 11:23 AM
    we run them as IAP no controller
    I looked up and my version should be able to go 8.6 directly
