Unable to upgrade AOS, partiton issues
  • 1.  Unable to upgrade AOS, partiton issues
    Posted Jul 04, 2016 08:56 PM
    Hi, Im have been trying to upgrade my 3400 wireless controller and followed the necessary documentation to upgrade the AOS from my PC.
    cpboot>setenv ipaddr x.x.x.x
    cpboot>setenv netmask x.x.x.x
    cpboot>setenv gatewayip x.x.x.x
    cpboot>setenv serverip x.x.x.x      (note: if you are running the tftp program on the same PC then the gatewayip and serverip should be same)
    Output:
     cpboot> ver
    CPBoot 1.3.0.1 (build 34416)
    Built: 2012-07-09 at 23:41:03
    cpboot> printenv
    bootargs=quiet
    bootcmd=bootf
    bootdelay=5
    baudrate=9600
    loadaddr=0x87000000
    psb_os_cpu_mask=0
    ethaddr=00:0b:86:99:44:44
    ipaddr=10.1.1.1                      <= Controller ip
    netmask=255.255.255.0
    gatewayip=10.1.1.2                <= PC IP
    serverip=10.1.1.2                   <= PC IP
    ethact=xlr_gmac3
    Environment size: 211/131068 bytes
    cpboot>
    cpboot> ping 10.1.1.2
    Using xlr_gmac3 device
    host 10.1.1.2 is alive
    cpboot> upgrade 1 ArubaOS_MMC_6.4.2.8_50314
    0: Device not present
    Invalid upgrade device: 0
    cpboot> upgrade 0 ArubaOS_MMC_6.4.2.8_50314
    How do i know which partition is present, i have tried 0, 1, 0:0, 0:1 . Is there a command to check the flash or if the disk are present.
    Any Workarounds that i can try ???
    The following is the displayed boot information
    System will be rebooted in about 1 seconds..
    DRAM:  Operating at 533 MHz
    DRAM:  Channel 0: 512 MB
    DRAM:  Channel 2: 512 MB
    DRAM:  Total = 1024 MB
    POST:  Memory test: Physical 0x00000000 - 0x10000000 - quick test
           Memory test: Physical 0x10000000 - 0x40000000 - quick test
    PASS
    CPU:   XLR516 rev. C4  Clock: 800MHz
    Board: A3400
    CPLD:  rev: 1.3
    SMP:   All 16 cpus successfully started
    Boot:  Primary bootflash partition
    POST2: OK
    Net:   xlr_gmac0 xlr_gmac1 xlr_gmac2 xlr_gmac3
    IDE:   Bus 0: Bus 0: not available
    Hit any key to stop autoboot:  0
    cpboot>
    cpboot>
  • 2.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 02:40 AM
    Please follow this article: http://community.arubanetworks.com/t5/Wireless-Access/3600-controller-out-of-space-when-boot-up/td-p/82024
    That procedure completely wipes/reformat your flash; where (I don't have a 3400 to test) you might need to do a "format 0:2" on the 3400 if the format 0 does not work.
    If the system is still under support, I would advise to contact Aruba TAC instead of trying yourself.
  • 3.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 08:11 AM
    Unfortunatly it was a ebay purchase so getting a Aruba support is a issue,on entering
    cpboot> format 0:2
    Format will erase everything on the internal flash's partition 2.
    Device 0 not present
    it dosent seem to do much, any other options i can try ?
  • 4.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 08:13 AM
    What is the result of "eye_finder"?
  • 5.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 09:16 AM
    It would seem the bootflash drive is physically missing in my device after opening it up, can some recommend the compatiable size, brand and model for my 3400 Controller.
    Thanks.
  • 6.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 09:41 AM
    Can you post a picture of the slot where the memory is missing?
  • 7.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 11:24 AM
    Assuming the slot in middle is missing the storage.
  • 8.  RE: Unable to upgrade AOS, partiton issues
    Posted Jul 05, 2016 11:56 AM
    Looks like a 512mb compact flash:
