Wired Intelligent Edge
Understanding the flow of a packet when using Fortigate Firewall
  • 1.  Understanding the flow of a packet when using Fortigate Firewall
    Posted Apr 08, 2024 03:07 AM
    I am new to Aruba Switches and Fortigate Firewalls and trying to understand the flow of a packet.
    We have NBN which connects into our WAN switch.  The WAN switch connects to our core switch.
    The core switch connects to a Fortigate Firewall and connects into our Edge Switches.
    On the core switch the default route 0.0.0.0 0.0.0.0 <ip address>.
    This <ip address> is configured inside Fortigate under the Aggregated Link as an IP Address for a Virtual LAN.
    If a host connected to an edge switch pinged google.com would the packet be sent to the core switch and then
    be passed to the Fortigate firewall and then sent to a Fortigate SD-Wan Internet Zone?
    What would the response packet hit?
  • 2.  RE: Understanding the flow of a packet when using Fortigate Firewall
    Posted Apr 08, 2024 03:18 AM
    If the routing between VLANs on your edge switches happens on the core switch, then you would need to configure a route to those subnets pointing to the core switch.
    If your core and edge switches are pure L2, then all routing should happen on your firewall. So it depends on how your network is designed and setup.
