Wired Intelligent Edge
Unifi SFP to Aruba SFP?
  • 1.  Unifi SFP to Aruba SFP?
    Posted Jun 10, 2022 04:21 PM
    I have two buildings connected via fiber with 2 unifi switches. One of the unifi switches will be replaced by a 2930F (JL262A). Both unifi switches are using an Ubiquiti U Fiber SFP+ LR (10Gb/s 10KM DDM TXr 1310nm).
    For the 2930F the SFP module that I see would be best to use is the Aruba 10G SFP+ LC LR 10km SMF Transceiver.
    I have only connected same vendor switches together. Would a unifi and aruba SFP transceiver work together?
    Thank you!
  • 2.  RE: Unifi SFP to Aruba SFP?
    Posted Jun 11, 2022 06:23 PM
    hi,
    if you have that SFP from uniquity UF-SM-10G  and Aruba's j9151e  SFP module it should work perfectly.
  • 3.  RE: Unifi SFP to Aruba SFP?
    Posted Jun 12, 2022 08:04 AM
    Awesome, thank you!
