unique-device-count - mac-address count
  • 1.  unique-device-count - mac-address count
    MVP
    Posted Jun 30, 2014 09:10 AM
    (clearpass)
    So we're using the unique-device-count from endpoint repository to keep users from registering too many devices with a guest network. Now we're getting reports of a user failing because he has used up his allowed number of devices.
    So, how can I check what mac-addresses this user has used?
    And how do I liberate one or more of those mac-addresses?
  • 2.  RE: unique-device-count - mac-address count
    Posted Jun 30, 2014 09:12 AM
    Search the username in the endpoint repository and then delete the entry you want to remove.
  • 3.  RE: unique-device-count - mac-address count
    MVP
    Posted Jun 30, 2014 09:42 AM
    Thank you, but how do I search for a username in the endpoint repository?
    I'm not currently saving the usernames with each endpoint so even if I could search here, I'm not sure this would be very helpfull right now.
    Surely that is not the only/best way?
  • 4.  RE: unique-device-count - mac-address count
    Posted Jun 30, 2014 10:34 AM
    Did you use the guest service template? It should be writing the guest username to the endpoint database.
    You could search in the guest UI for the username as well.
  • 5.  RE: unique-device-count - mac-address count
    MVP
    Posted Jun 30, 2014 11:13 AM
    Not sure at this time.. but even if I did, the only way to search that endpoint repository for usernames appears to be a manual search after exporting all the records.. surely there's a bit more streamlined process to do this?
    And where in the guest ui can I search for usernames and get all the different mac-addresses associated with that username then? I'm looking but I can't find any such search?
  • 6.  RE: unique-device-count - mac-address count
    Posted Jun 30, 2014 11:26 AM
    Sorry, only the endpoint repository.
  • 7.  RE: unique-device-count - mac-address count
    MVP
    Posted Jun 30, 2014 11:37 AM
    Thanks. Never noticed you could search any attribute there.
    This is pretty much what I was looking for.
