Network Management
"Unknow Error - _ssl.c:477: The handshake operation timed out"
  • 1.  "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Mar 21, 2016 08:23 AM
    Receiving the following error in ClearPass this morning:
    Check Subscription ID, Network Connectivity, http_proxy credentials.
    Click on 'Check Status Now' after correcting the configuration.
    I can connect to my ClearPass via an internet connection so I am pretty sure that its network connectivity is working.   I've tried "Check Status Now' twice.  Running version 6.5.5.78974
    Anyone else receiving, have received, this error?
  • 2.  RE: "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Mar 21, 2016 08:42 AM
    Can you please try again by clicking on "Check Status Now?"
  • 3.  RE: "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Mar 21, 2016 08:51 AM
    Yes.
    Seems to be working now.  No more error.   "Done querying for updates from ClearPass Webservice"  Thanks.
    Was there a problem?
  • 4.  RE: "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Mar 21, 2016 08:52 AM
    We are looking into it.  Others saw the error message as well.
  • 5.  RE: "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Mar 21, 2016 08:55 AM
    Understood.  Much thanks.
    Jason....
  • 6.  RE: "Unknow Error - _ssl.c:477: The handshake operation timed out"
    Posted Apr 12, 2017 12:31 PM
    I am seeing this same issue on both of my clearpass servers, any updates?
