Unknown Certificate - Radius Active Directory Authentification
  • 1.  Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 04:58 AM
    Hello everyone,
    Sorry if this questions has already been asked, but I cant seem to find an answer.
    Im designing a very simple Wifi architecture for my company, only 130 people, composed of 15 Aruba IAP-207 Access points.
    For our Employee Wifi Network, I want my users to authenticate with their AD logins with 802.1x, quite simple.
    It works very great, the only thing I cant do is to bypass a certificate warning.
    I've created a self signed certificate to auth my radius server and allow the 802.1x authentification. For the company own-devices, I think I'll be able to push a GPO and install the certificate, but what about the personal laptops and smartphones ? Anyway to get around the warning ?
    I've joined a 2 screenshots, 1 warning on Apple and the other one on Windows 10.
    Thanks a lot !
    François-Xavier
  • 2.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 05:25 AM
    For company devices you can push a GPO with the correct settings.
    For personal devices it's not possible to prevent this certificate message. It's just a validation message.
    Next to this, it's not advisable to use EAP-PEAP at unmanaged devices because EAP-PEAP is broken years ago. EAP-PEAP is save when you do proper certificate checking at the client.
  • 3.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 06:07 AM
    Hi Willem,
    Thanks for the reply.
    That would be the best option to authenticate unmanaged devices with Active Directory credentials ?
    Thanks !
    François-Xavier
  • 4.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 06:43 AM
    If you use EAP-PEAP don't use your AD credentials. Better option is to use EAP-TLS. ClearPass Onboard can be a solution for this.
  • 5.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 08:56 AM
    It cant be done with Instant, you need Clearpass ? And what about direct LDAP queries ? Is that a viable option ?
    Thanks a lot :)
  • 6.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 09:05 AM
    Yes, for Onboard you need ClearPass.
    LDAP is not a solution.
    EAP-PEAP works but it's not secure. It's relative issue to capture the password hash. Because the hash is MD4 encrypted it's possible to decrypt the hash.
  • 7.  RE: Unknown Certificate - Radius Active Directory Authentification
    Posted May 28, 2019 09:36 AM
    Please work with your Aruba partner.
