unknown IP Address
This thread has been viewed 19 times
  • 1.  unknown IP Address
    Posted May 29, 2021 11:36 PM
    Hi to all,
    im trying to verify master-l3 redundancy on my 2xMobility Conductor. any idea what "to Master Switch at unknown IP address : succeeded" means?
    im using 8.5.0.12_79365.
    TIA :)
    Harvey Ysip
  • 2.  RE: unknown IP Address
    MVP EXPERT
    Posted Jun 01, 2021 07:18 AM
    Is the L3 redundancy set up correct, along with the correct IP addressing? Is this L3 master part of the same Mobility Conductor cluster? You should see the IP address is configured correctly.
    Craig Syme
