@fjulianom@hotmail.com wrote:
Hi everyone,
I don't know why but everytime I access to my controller by WebUI, I get this entry in the CPPM Access Tracker:
![accesscontr1.PNG accesscontr1.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/61078cb056ac474880970c115515f085_a607347beaec4676bf5fb643e8246732)
![accesscontr2.PNG accesscontr2.PNG](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/61078cb056ac474880970c115515f085_9812ed1253274ec18f5fdf762ae670fb)
The reason is there isn't a service for this, but I am accessing to my controller and not connecting to any network. I guess there is some wrong configuration in my controller, what should I check?
Julián
On the Aruba Controller if if you have "Enable" configured under Configuration> Management> Administration> Management Authentication servers, it will attempt to first authenticate you using the server group listed under "Server" group, and if it fails, it will attempt to authenticate a local user. In a master/local cluster, this option is global, so if you turn it on for the master, you turn it on for all locals as well. It is possible that you copied this configuration from a master/local cluster that had it enabled. Just uncheck "Enable" to make it stop.
![Screenshot 2017-07-14 at 20.36.02.png Screenshot 2017-07-14 at 20.36.02.png](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/61078cb056ac474880970c115515f085_c0bbf8dc2d5b4a4f8b90e3514af25260)
