UnknownAutzParams - Juniper / Trapeze CoA
  • 1.  UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 11:42 AM
    Hi Everyone,
    I am trying to send a CoA request to a Juniper (Trapeze) WLC 880R.
    I am getting the following errors in the logs from the Enforcement Policy.
    DEBUG Core.PETaskRadiusCoAEnfProfileBuilder - Adding attr=Radius:IETF:NAS-IP-Address|value=%{Application:WebLoginURL:portal_ip} to the EnforcementProfile outlist
    DEBUG Core.PETaskRadiusCoAEnfProfileBuilder - Adding attr=Radius:IETF:Calling-Station-Id|value=%{Connection:Client-Mac-Address-Colon} to the EnforcementProfile outlist
    DEBUG Core.PETaskRadiusCoAEnfProfileBuilder - Adding attr=Radius:IETF:Filter-Id|value=ClusterPermitALL.in to the EnforcementProfile outlist
    DEBUG Core.PETaskRadiusCoAEnfProfileBuilder - Adding attr=Radius:Trapeze:Trapeze-CoA-Username|value=%{Authentication:Username} to the EnforcementProfile outlist
    DEBUG Core.PETaskRadiusCoAEnfProfileBuilder - buildParamsToFetch: Building parameters to fetch for RadiusCoAEnforcement
    INFO Core.PETaskRadiusCoAEnfProfileBuilder - UnknownAutzParams to fetch for RadiusCoAEnfProfiles: :
    INFO Core.PETaskRadiusCoAEnfProfileBuilder - UnknownNAutzParams to fetch for RadiusCoAEnfProfiles: :
    I can see no payload even arriving at the Receving WLC.
    Any Ideas?
    Jaggie
    CP 6.6
  • 2.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 12:08 PM
    Try this and see if it works:
  • 3.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 12:57 PM
    Hi Victor,
    I added the the Framed IP Addrress as this was the only thing that was different in my policy to your screenshot.
    I am assuming that the order doesn't make any difference?
    Jaggie
  • 4.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 02:01 PM
    No
    Sent from Outlook for iPhone
  • 5.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 02:03 PM
    Unfortunately I have the exact same error.
    John
  • 6.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 02:39 PM
    Do you have accounting enabled on the trapeze WLC ?
  • 7.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 03:02 PM
    Nope accounting is not enabled but I have added the CP server as a DAC server on the WLC.
    I have other DAC servers that can make CoA requests to these WLCs and accounting is not enabled for them either.
    Jaggie
  • 8.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 03:14 PM
    I ran into an issue with CoA and trapeze when accounting was enabled.
    Also how do you have the trapeze WLC identified as under network devices ?
  • 9.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 03:23 PM
    Accounting is enabed on CP but not on the Juniper WLC.
    CP is doing accounting for an Aruba Mobility Controller.
    The device is declared as "Trapeze" but I have also tried to swap this to "Juniper" with the same error.
    Jaggie
  • 10.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 21, 2016 07:22 PM
    Please change it to IETF as vendor name
  • 11.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 22, 2016 02:31 AM
    Changing it to IETF shows the same error.
    Jaggie
  • 12.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Apr 23, 2016 11:31 AM
    Hi Victor,
    Do you have any other ideas?
    Jaggie
  • 13.  RE: UnknownAutzParams - Juniper / Trapeze CoA
    Posted Sep 28, 2016 03:18 AM
    Having the very same issue on clearpass 6.6.2 when sniffing the network no CoA leaves the clearpass. I had the setup partually working on 6.6.1 but the CoA was only sent sometimes (often not during the first auth but then with the second try). this applies to mac auth (mac caching). webauth (portal) worked fine but also broke during further testing (same enforcement profile).
    any ideas someone?
