Unplugging Stacking Member
  • 1.  Unplugging Stacking Member
    Posted Nov 02, 2015 03:17 PM
    Hi.
    I have a S2500 that also acts as our Primary Router and another S2500 that will be uplinked to the Router soon, in the same closet, though just as a standard switch.
    I just received some fiber to run as our backbone, so I plugged a SFP into a SFP port on the router and also on the second S2500, so they could then communicate. I wanted to test to see if I had to configure anything to get the fiber to work, once I ran it.
    I searched in vain for data on how to connect a fiber backbone, but all I could find was stuff on stacking, so I assume Aruba uses stacking when connecting a fiber backbone?
    Anyway, the problem is when I unplugged the SFP from the main router all ports on the router went black and the network was dead, though the router was still running.
    I plugged the SFP and fiber back in to the original ports and the router ports lit up and all is well.
    Problem is, I don't want the second S2500 to be connected to the router via that fiber.
    My main question is; How can I undo what I did?
    And, not as important, how do I uplink my two closets via fiber? Is it through stacking?
    Thank you!
  • 2.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:23 PM
    What physical interfaces did you use to connect the fiber?
  • 3.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:33 PM
    Hi Thanks for the response
    Here is what I have:
    Also, I just disabled the split detection via the GUI. Hopefully, that
    prevents the router from going dark on secondary shutdown.
    Aruba-DataCenter-1) #show stacking interface
    stack1/2
    stack1/2 is administratively Enabled, link is Up, line protocol is Up
    Speed: 10 Gbps, MTU: 9224 bytes, Link flaps: 3
    Last update of counters: 0d 00:00:07 ago
    Last clearing of counters: 0d 02:04:03 ago
    Link status last changed: 0d 00:12:35 ago
    Statistics:
    Received 498665 frames, 129681275 octets
    12 pps, 15.292 Kbps
    184113 broadcasts, 0 runts, 0 giants, 0 throttles
    0 error octets, 0 CRC frames
    64999 multicast, 249553 unicast
    Transmitted 2149639 frames, 784909578 octets
    29 pps, 34.388 Kbps
    543320 broadcasts, 0 throttles
    69000 multicast, 1537319 unicast
    0 errors octets, 0 deferred
    0 collisions, 0 late collisions
    stack1/3
    stack1/3 is administratively Enabled, link is Down, line protocol is Down
    Speed: N/A, MTU: 9224 bytes, Link flaps: 0
    Last update of counters: 0d 00:00:00 ago
    Last clearing of counters: 0d 00:00:00 ago
    Link status last changed: 0d 00:00:00 ago
    Statistics:
    Received 0 frames, 0 octets
    0 pps, 0 bps
    0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 multicast, 0 unicast
    Transmitted 0 frames, 0 octets
    0 pps, 0 bps
  • 4.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:38 PM
    OK...so if port 1/3 is in use and active, that is acting as a stacking port on the Aruba switch.  Is port 0 or 1 avaialble?  If so, you can just use those as a normal switch interconnect/uplink like any other port on the switch.
  • 5.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:48 PM
    OK. Good.
    But, how do I remove these two switches from being stack members?
    My Router is reading as Secondary when I plug in the other S2500, but it
    then says Primary when I unplug the other switch. Wow, I dug myself in this
    time.lol
    Thanks for your help Seth!
  • 6.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:53 PM
    OK...on the second unit, issue this command after it's been removed from the stack...
    restore factory-default stacking
  • 7.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 04:57 PM
    You can also do this to use ports 1/2 and 1/3 as regular uplinks...this will remove them from being "stack" ports..
    delete stacking interface stack 1/2
  • 8.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 05:16 PM
    Thank you. I will issue that command to gladly get rid of them. But, how do
    I remove the switch from the stack? I deleted it from via the GUI, under
    configuration, stacking, but I can only communicate with it via the
    routers' IP.
    Sorry about this.
  • 9.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 05:17 PM
    No worries but I'd call into support and have them help you walk through this just so you gracefully exist this config with no unknown artifacts
  • 10.  RE: Unplugging Stacking Member
    Posted Nov 02, 2015 05:20 PM
    Thank you very much for your help. I will call them.
