Unprovisioned Access Points not detected
  • 1.  Unprovisioned Access Points not detected
    Posted Dec 11, 2012 10:44 PM
    hi all, i am doing config in my new aruba controller 650 an acess points ap-135. there is a problem that Unprovisioned Access Points is not detected in my controller. i have already configured dhcp server in my controller and the ap is get dynamic ip from controller. i can ping the controller from acces points. i have read the forum and CP Sec disabled.
    this is the ping  :
    PING 10.200.50.253 (10.200.50.253): 56 data bytes
    64 bytes from 10.200.50.253: icmp_seq=0 ttl=64 time=2.4 ms
    64 bytes from 10.200.50.253: icmp_seq=1 ttl=64 time=1.0 ms
    64 bytes from 10.200.50.253: icmp_seq=2 ttl=64 time=1.0 ms
    64 bytes from 10.200.50.253: icmp_seq=3 ttl=64 time=1.5 ms
    64 bytes from 10.200.50.253: icmp_seq=4 ttl=64 time=1.4 ms
    --- 10.200.50.253 ping statistics ---
    5 packets transmitted, 5 packets received, 0% packet loss
    this is controller ip :
    #show controller-ip
    Switch IP Address: 172.16.0.254
    Switch IP is configured to be Vlan Interface: 1
    Switch IPv6 address is not configured.
    this is ap database :
    #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
    I = Inactive; H = Using 802.11n license; D = Dirty or no config
    X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-b
    ased RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
    M = Mesh node; Y = Mesh Recovery
    Total APs:0
  • 2.  RE: Unprovisioned Access Points not detected
    Posted Dec 11, 2012 10:53 PM
    Yes is detected...
    Look check that its not in access denied on the monitoring tab on the summery it should appear in read you click on it and it will say access denied...
    Now at this poing you need to give it permission.
    If you want to do it the easy way you can go to the configuration tab, and go to the  control security plane
    Check autocert provisioning... and then click ok
    When you done then you revert that change... thats for security reasons... but well you can do it like that faster...
  • 3.  RE: Unprovisioned Access Points not detected
    Posted Dec 11, 2012 10:55 PM
    Oh didnt read you have CP off...
    IF you dont see it on the controller try consoling the AP to see if he find the Aruba master with the correct ip address
    I see you got the AP on another network
    Did you put the aruba-master record on the DNS pinting to 172.16.0.254
    So when the AP comes up he knows thats the ip of the master?
    And of course ont he DHCP server did you configured the DNS server i mean the internal DNS server which tells the AP which will be the aruba master?
  • 4.  RE: Unprovisioned Access Points not detected
    Posted Dec 11, 2012 11:25 PM
    how to find the Aruba master with the correct ip address in ap console ?
    I still using default ip address for the controller.
    i have already set vlan 800 with ip address 10.200.50.253 with dhcp server and the ap get an ip 10.200.50.252
    i have already set gi1/5 access with vlan 800 and connect my ap to that.
    sorry if i ask a basic question :)
    this is ap log :
    cli| ADRS provision failed, code: connection-failed
    Jan 1 00:32:22 cli[1177]: <341004> <WARN> |AP 6c:f3:7f:c3:67:28@10.200.50.252
    cli| Isc_send_request
    Jan 1 00:32:53 cli[1177]: <341005> <ERRS> |AP 6c:f3:7f:c3:67:28@10.200.50.252
    Jan 1 00:33:24 cli[1177]: <341004> <WARN> |AP 6c:f3:7f:c3:67:28@10.200.50.252
  • 5.  RE: Unprovisioned Access Points not detected
    Posted Dec 11, 2012 11:38 PM
    okay let see
    you got set this way up
    you got the Controller set on 172.16.0.254
    You also did an interface vlan with the ip 10.200.50.253
    Okay go the webgui go to configuration go to controller and on the controller ip details you will see this address on it
    172.16.0.254 which should be on vlan 1
    On the dropdown choose vlan800 10.200.50.253 it should appear
    click apply
    save the configuration
    And you will need to reboot the controller...
    Now the thing is that you should always point the AP  to the master IP address and now the master ip address is 172.16.0.254
    For him aruba-master = 172.16.0.254 not 10.200.50.253
    With the change i just told you the aruba-master will be  10.200.50.253 and it should find it correctly after you reboot
    Now if you trunking that vlan 800 to your internal network then you shoud put the default gatway of that network pointing to the switch that is routing that vlan...
    But for now just do the change i just told you and the AP should come up...
    Before rebooting you can put another port on vlan 800 if you would like and you can plug your laptop or computer there and well save the config
  • 6.  RE: Unprovisioned Access Points not detected
    Posted Dec 11, 2012 11:46 PM
    Im guessing you are doing this offline you your pc and the controller and the AP just to test though....
    But when you connect it ot the real Network you will have your APs on another vlan
    Let say
    You got your controller with vlan 800 with the ip you said 10.200.50.253
    You got that vlan trunked to your switch core and then trunked that vlan 800 back and on the switch core an ip interface vlan which will be the default gateway of that Wireless controller... let say you will have an ip interface vlan with the ip 10.200.50.1 on the SwitchCORE
    And your default gateway will be the CORE switch which is routing that vlan(for now thecontroller should be just a layer 2 at this momment which is recommended.
    Now just with that you should have aministration on the network of the Wireless contorller.
    Now the APs might not be on that vlan... they will be in X vlan...
    So now you got the dilema that you need your APS can find the controller.
    It can be done in many ways....
    1-By statically configuring it
    2-by DNS
    3-by DHCP
    4-with ADP protocol(which will find it if the AP is on the same vlan of the Wireless controller)
    I llike the DNS one
    On the DNS server you put a new record aruba-master which willl be 10.200.50.253
    Now if you connect the AP on any vlan that has a DHCP server that distribute the DNS server ip on that dhcp scope  he willl get the IP in X vlan and also but as he will resolve with the DNS server that the master is 10.200.50.253 he willl find the controller and you should see it ont he screen.
    Hope this help you
  • 7.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:07 AM
    @ Im guessing you are doing this offline you your pc and the controller and the AP just to test though....
    you are right :)
    I am still looking for how to configure this stuff
    Can you explain in details this :
    1-By statically configuring it >> might be this is the easy way but i have to do it on ap's console ?
    2-by DNS
    3-by DHCP
  • 8.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:08 AM
    Lets go step by step
    Can you see the AP now you did what i told you ?
  • 9.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:11 AM
    i have done this :
    okay let see
    click apply
    but still cant detect it
  • 10.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:13 AM
    this is tha ap sum
    # show sum
    Domain :
    Address :0.0.0.0
    Content Filtering :disable
    Terminal Access :disable
    Organization :
    Airwave Address :0.0.0.0
    Airwave Shared Key :
    Airwave Config Via :DHCP
    Syslog Server :0.0.0.0
    Syslog Level :warn
    Band :all
    Master *:10.200.50.252
    Master Key :6191342201c1e2d5c326e7e9c7023749e56da72af4c1e967da
    Elected Time :12m:51s
    Mesh :enable
    Dynamic Radius Proxy :disable
    NTP Server :
    Configuration Dirty :disable
    Allow New APs :enable
    Classification :disable
    Wireless Containment :disable
    Wired Containment :disable
    Rogue Containment :disable
    LED Off :disable
    Airwave :Not Set Up
    Image Server State :success
    Image Server Message :Success
    New Image Version :
    New Image URL :
    Factory SSID :instant
    Image Sync Via :Master
    Client Alerts :0
    Active Faults :0
    IP Address :10.200.50.252
    Serial Number :AX0141813
    OpenDNS Status :Not connected
    TFTP Dump Server :0.0.0.0
    VPN Status :Not Set Up
    0 Clients
    MAC Name IP Address Network Access Point
    1 Network
    Key Name Clients
    instant instant 0
    1 Access Point
    MAC IP Address Name Clients Need Antenna Confi
    g
    6c:f3:7f:c3:67:28 10.200.50.252 6c:f3:7f:c3:67:28 0 No
    RADIUS Servers
    Name IP Address Port Key
    Timeout Retry Count NAS IP Address NAS Identifier RFC3576
    InternalServer 127.0.0.1 1616 4b4f5340018718468e84e46eebb559ae8fbcb438a87415
    bb05 5 3
    RTLS Servers
    Type IP Address Port Key Frequency
    Aeroscout 0.0.0.0 0
    Airwave 0.0.0.0 0 0
    1 AP Class
    Name APs
    Cassiopeia 1
    Uplink type :Ethernet
    Uplink status :UP
    Manual Blacklist Count :0
    Dyn Blacklist Count :0
    Certificate Installed: :No
    Internal Radius Users: :0
    Internal Guest Users: :0
    Info timestamp :813
  • 11.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:15 AM
    wait a second! is that an instant AP???
    When you connect it do you see on the wireless a instant SSID?
  • 12.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 12:23 AM
    Look if its an instant AP and you DO NOT want to use it as instant AP and it will be a managed AP by the wireless controller you need to convert it to managed AP...
    Remenber this is if you dont want to use it as Instant AP.
    Let say you dont want it to use it as INSTANT AP and you would like to use it as a AP managed by the wireless controller which i see is what you want
    You connect to the SSID instant,
    user
    admin
    pass
    admin
    Go to maintanience tab i think its the name
    And you should see a tab in there to convert it... he will ask you whats the IP of the controller you put in there.. and he will convert...
  • 13.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 01:40 AM
  • 14.  RE: Unprovisioned Access Points not detected
    Posted Dec 12, 2012 08:41 AM
    Yes thats what i think!
  • 15.  RE: Unprovisioned Access Points not detected
    Posted Dec 23, 2012 10:51 PM
    how i can convert user console because i have tried it using web but still cant convert it
  • 16.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 01:45 AM
    See if the access point is broadcasting the "Instant" wireless network.  If it is connect to it using your laptop and see if you get an ip address....
    If you get an ip address with your laptop, open a browser and try to go to http://instant.arubanetworks.com.  If a page comes up for the Instant virtual controller, login with "admin" and "admin".  If you get in go to Maintenence> Convert and Convert to Campus AP and point it to the ip address of your controller to convert it.
  • 17.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 02:36 AM
    thank you, now i can convert my 135 ap's
  • 18.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 02:40 AM
    Awesome.  Happy Holidays!
  • 19.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 02:59 AM
    now ia have a problem with this one.
    Model: AP-13x
    CPU: 88F6560 A0 (DDR3)
    Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
    DRAM: 256MB
    POST1: passed
    Flash: 16 MB
    Power: DC
    LAN: done
    PHY: done
    PEX 0: RC, link up, x1
    bus.dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00.00 00 11ab 6560 00005 02 f1000000 00000000 00000000 00000000
    00.01 00 168c 0030 00002 01 90000000 00000000 00000000 00000000
    PEX 1: RC, link up, x1
    01.00 00 11ab 6500 00005 02 f1000000 00000000 00000000 00000000
    01.01 00 168c 0030 00002 01 94000000 00000000 00000000 00000000
    Net: eth0, eth1
    Radio: ar9390#0, ar9390#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xf8100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xf8800000
    Invalid image format version: 0xc
    This AP is delivered without os image. Can i copy the os image from another ap? I have already searching ap's os image but still cant find it.
  • 20.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:02 AM
    Is that the only AP with the problem?  What is the controller's OS version?
    The controller should deliver the OS to the AP.
  • 21.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:04 AM
    this is my cotroller
    Name:Aruba Operating System Software.
    Model:Aruba650
    Version:6.1.3.5
    Compiled:2012-09-28 at 07:46:05 PDT (build 35523) by p4build
    WebSite:http://www.arubanetworks.com
    Legal:
    Copyright (c) 2002-2012, Aruba Networks, Inc.
    i have config 2 of them but this one is came with that messege
  • 22.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:06 AM
    Okay.
    On the console of that AP, press enter to interrupt the boot until you get to the "apboot>" prompt.
    type "clear os" and reboot.
    It should come up as an instant AP again.  Connect to the "instant" SSID and try to convert once more...
  • 23.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:09 AM
    still with that message :
    apboot> clear os
    Erasing flash sector @ 0xf8100000....done
    Erased 1 sectors
    apboot> ?
    ? - alias for 'help'
    boot - boot the OS image
    clear - clear the OS image or other information
    dhcp - invoke DHCP client to obtain IP/boot params
    factory_reset - reset to factory defaults
    help - print online help
    mfginfo - show manufacturing info
    osinfo - show the OS image version(s)
    ping - send ICMP ECHO_REQUEST to network host
    printenv - print environment variables
    purgeenv - restore default environment variables
    reset - Perform RESET of the CPU
    saveenv - save environment variables to persistent storage
    setenv - set environment variables
    tftpboot - boot image via network using TFTP protocol
    upgrade - upgrade the APBoot or OS image
    version - display version
    ÿpboot> reset
    APBoot 1.2.6.7 (build 30025)
    Built: 2011-08-30 at 17:41:16
    Model: AP-13x
    DRAM: 256MB
    POST1: passed
    Flash: 16 MB
    Power: DC
    LAN: done
    PHY: done
    Net: eth0, eth1
    eth0: down
    eth1: down
    ADP multicast 1
    ADP broadcast 1
    Abort
    apboot>
  • 24.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:11 AM
    Don't worry about that message.  Type "dhcp" at the apboot> prompt to see if it gets an ip address.  I don't see that happening...
    I also do not see the link coming up on eth0...
  • 25.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:19 AM
    apboot> dhcp
    eth0: up, 100 Mb/s, full duplex
    DHCP broadcast 1
    DHCP IP address: 10.200.50.251
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 10.200.50.254
    DHCP DNS server: 10.200.50.254
    DHCP DNS domain: xxxxxxxxxxx
    Controller address: 2xx.1xx.2xx.4x
  • 26.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:29 AM
    okay.  type "boot" and let us see the output..
  • 27.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:32 AM
    apboot> boot
    Using eth0 device
    TFTP from server 2xx.1xx.2xx.4x; our IP address is 10.200.50.251; sending throug
    h gateway 10.200.50.254
    Filename 'armv5te.ari'.
    Loading: ###########T ######T #########T ##T ###T ######T ############T #T ###T
    ##T ##T #T #T
    done
    Bytes transferred = 3858304 (3adf80 hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x02000000 ...
    ## Booting image at 02000200 ...
    Uncompressing... done
    Aruba Networks
    ArubaOS Version 6.1.3.5 (build 35523 / label #35523)
    Built by p4build@corsica.arubanetworks.com on 2012-09-28 at 07:20:25 PDT (gcc ve
    rsion 4.3.3)
    Memory: 256MB = 256MB total
    Memory: 245376KB available (2564K code, 8864K data, 2768K init, 0K highmem)
    Calibrating delay loop... 1597.44 BogoMIPS (lpj=1597440)
    PEX0 interface detected Link X1
    PEX1 interface detected Link X1
    wdt: registered with refresh
    Enabling Watchdog
    i2c /dev entries driver
    i2c-arran: using default base 0xf1018100
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: active-staEthernet Channel Bonding Driver: v3.5.0 (Novembe
    r 4, 2008)
    ndby
    eth0: link up, full duplex, speed 100 Mbps
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    bonding: bond0: making interface eth0 the new active one.
    bonding: bond0: first active interface up!
    bonding: bond0: enslaving eth0 as an active interface with an up link.
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    eth1: link down
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    eth1: link down
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 51, num_radios 2 (jiffies 1845)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is register
    ethernet_device_event: dev eth0 is up
    setting bond0 as bridge child
    setting gre0 as split child
    Starting watchdog process...
    Got all network params from APboot env. Skipping DHCP
    172.16.1.3 255.255.255.0 172.16.1.1
    Running ADP...eth0: link up, full duplex, speed 100 Mbps                    >>>> i press ctrl+c
    ^C~ #
  • 28.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:35 AM
    That looks right...
    On the controller, type "show log system 50" and then type "show ap database"
  • 29.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:47 AM
    Cotroller log :
    Dec 21 14:18:43 KERNEL: 2:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    Dec 21 14:18:52 :304001: <ERRS> |stm| Unexpected stm (Station management) runtime error
    at data_path_handler, 642, data_path_handler: recv - Network is down
    Dec 24 09:48:30 :303022: <WARN> |AP d8:c7:c8:cc:36:c2@10.200.50.251 nanny| Reboot Reaso
    n: No reboot message found.
    Dec 24 09:50:58 :311010: <WARN> |AP d8:c7:c8:cc:36:c2@10.200.50.251 sapd| AP could not b
    oot from flash -- bad checksum                         >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> i think this the one right ?
    Dec 24 13:35:16 :303022: <WARN> |AP 6c:f3:7f:c3:67:30@10.200.50.250 nanny| Reboot Reaso
    n: AP rebooted Sat Jan 1 00:13:00 UTC 2000; Image Upgrade Successful
    Dec 24 13:58:39 :311002: <WARN> |AP 6c:f3:7f:c3:67:30@10.200.50.250 sapd| Rebooting: SA
    PD: Rebooting after provisioning
    Dec 24 13:58:39 :303086: <ERRS> |AP 6c:f3:7f:c3:67:30@10.200.50.250 nanny| Process Manag
    er (nanny) shutting down - AP will reboot!
    Dec 24 13:59:17 :303022: <WARN> |AP 6c:f3:7f:c3:67:30@10.200.50.250 nanny| Reboot Reaso
    n: AP rebooted Mon Dec 24 13:58:39 SAST 2012; SAPD: Rebooting after provisioning
    Dec 24 14:04:29 :311002: <WARN> |AP 6c:f3:7f:c3:67:30@10.200.50.250 sapd| Rebooting: SA
    Dec 24 14:04:29 :303086: <ERRS> |AP 6c:f3:7f:c3:67:30@10.200.50.250 nanny| Process Manag
    AP Database :
    # show ap database
    AP Database
    AP-135-01 xxxxxxx 135 1.1.1.7 Up 54m:38s R 2xx.1xx.2xx.4x
    AP-135-02 xxxxxxx 135 1.1.1.6 Down R 2xx.1xx.2xx.4x
    R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP;
    Total APs:2
    I have already configured 2 aps
    the new one is not detected
  • 30.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:50 AM
    The message "Dec 24 09:50:58 :311010: <WARN> |AP d8:c7:c8:cc:36:c2@10.200.50.251 sapd| AP could not b
    oot from flash -- bad checksum" just says why it rebooted.  The fact that the message is there means that it recovered and it contacted the controller.  It should show up in "show ap database"
    at the "apboot>" prompt, type "purge" then "save", then "boot"
  • 31.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 03:59 AM
    how i can change the boot method from tftp boot to flash. i still looking for the image of the ap but cant find it. can i copy the image ap from the other one?
    so it will be the same with other ap that i have configured
  • 32.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 04:07 AM
    When the AP boots with the message:
    rsion 4.3.3)
    It already has an image....  The next thing you need to see is if it is finding the controller.
    At the beginning of this thread you sent this output:
    #show controller-ip
    That means if the AP contacts the controller on ANY ip address, it will redirect the AP to 172.16.0.254.  That happens because the controller by default assigns its switch IP to the LOWEST vlan on the box.  You can change this by:
    config t
    controller-ip vlan <vlan#>
  • 33.  RE: Unprovisioned Access Points not detected
    Posted Dec 24, 2012 04:22 AM
    thank you verry much, you are verry helpfull. i have configured all of the APs
    #show ap database
    AP Database
    AP-135-01 Indosat 135 1.1.1.7 Up 1h:33m:31s R 202.138.246.46
    AP-135-02 Indosat 135 1.1.1.6 Down R 202.138.246.46
    AP-135-03 Indosat 135 1.1.1.8 Up 3m:1s R 202.138.246.46
    Total APs:3
