Comware
Unreachable switch for management
  • 1.  Unreachable switch for management
    Posted Sep 25, 2023 10:45 AM
    I have Aruba switch CX 6100 and switch won't reachable for any management access. I was connect to switch over console cable (yes really I was must go on place), I am looking for default route
    40# sh ip route
    Displaying ipv4 routes selected for forwarding
    Origin Codes: C - connected, S - static, L - local
    VRF: default
    Prefix              Nexthop                                  Interface     VRF(egress)       Origin/   Distance/    Age
        Type      Metric
    0.0.0.0/0           10.2.20.1                                vlan120       -                 S         [1/0]        00h:00m:42s
    10.2.20.0/24        -                                        vlan120       -                 C         [0/0]        -
    10.2.20.40/32       -                                        vlan120       -                 L         [0/0]        -
    40# show runn | inc route
    ip route 0.0.0.0/0 10.2.20.1
    BUT ...  I am starting shell and I see that default route not up in system:
    40# start-shell
    40:~$ ip ro show
    10.2.20.0/24 dev vlan120 proto kernel scope link src 10.2.20.40
    240.0.0.0/16 dev tap0 proto kernel scope link src 240.0.0.1
    40:~$ ip ro ad default via 10.2.20.1
    RTNETLINK answers: Operation not permitted
    40:~$ sudo ip ro ad default via 10.2.20.1
    40:~$ ip ro s
    default via 10.2.20.1 dev vlan120
    40:~$ exit
    now is switch management reachable.
    40# show version
    ArubaOS-CX
    (c) Copyright 2017-2023 Hewlett Packard Enterprise Development LP
    Version      : PL.10.12.0006
    Build Date   : 2023-05-31 22:50:01 UTC
    Build ID     : ArubaOS-CX:PL.10.12.0006:6705ece9e13b:202305312204
    Build SHA    : 6705ece9e13b7bda1f30567bf7b837062878ac24
    Hot Patches  :
    Active Image : primary
    Service OS Version : PL.01.12.0003
    BIOS Version       : PL.01.0002
    40# show system
    Hostname               : 40
    System Description     : DR2
    System Contact         :
    System Location        : Nad kompresorem CW
    Vendor                 : Aruba
    Product Name           : JL676A 6100 48G 4SFP+ Swch
    Chassis Serial Nbr     : CN29KNG0SH
    Base MAC Address       : ec50aa-23fb40
    ArubaOS-CX Version     : PL.10.12.0006
    Time Zone              : Europe/Prague
    Up Time                : 6 days, 19 hours, 33 minutes
    CPU Util (%)           : 9
    CPU Util (% avg 1 min) : 26
    CPU Util (% avg 5 min) : 14
    Memory Usage (%)       : 27
    This is a BUG or .....?
  • 2.  RE: Unreachable switch for management
    Posted Sep 29, 2023 12:50 AM
    next one with the same fw is unreachable because lost defaul gateway from system. It is realy interesting, i mean that this behavior isn't good. I use cheaper switch from EdgeCore too and those never losed gateway - this is the basic!
    I will be testing new firmware ArubaOS-CX_6100-6000_10_12_1000, however in release notes isn't note about this.
    R.
