Here is part of the config
<LAB-HP5700>dis cur
version 7.1.045, Release 2432P61
sysname LAB-HP5700
clock timezone CST minus 06:00:00
clock summer-time CDT 02:00:00 March second Sunday 02:00:00 November first Sunday 01:00:00
clock protocol ntp
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 32
irf member 2 priority 1
irf mode normal
irf-port 1/1
port group interface FortyGigE1/0/41
irf-port 2/2
port group interface FortyGigE2/0/42
stp instance 0 priority 12288
stp mode rstp
stp global enable
interface Bridge-Aggregation1
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 1002 1004 1006 1008 1060 1100 1102 1299 2008 2100 to 2109
port trunk permit vlan 3004 3008
port trunk pvid vlan 901
link-aggregation mode dynamic
interface Bridge-Aggregation2
description 1Gig to 2930F cores
interface Bridge-Aggregation10
description 40Gig to 8360s
port trunk permit vlan 1 1002 1004 1006 1008 1060 1100 1102 1299 2008
port trunk permit vlan 2100 to 2109 3004 3008
interface NULL0
interface Vlan-interface1002
ip address 10.80.2.10 255.255.255.0
interface FortyGigE1/0/42
port link-aggregation group 10
interface M-GigabitEthernet0/0/0
mad bfd enable
mad ip address 192.168.80.11 255.255.255.0 member 1
mad ip address 192.168.80.12 255.255.255.0 member 2
interface Ten-GigabitEthernet2/0/41:1
port access vlan 1100
interface Ten-GigabitEthernet2/0/41:2
interface Ten-GigabitEthernet2/0/41:3
interface Ten-GigabitEthernet2/0/41:4
scheduler logfile size 16
Original Message:
Sent: Jun 28, 2024 10:48 AM
Subject: Unsplit 40G interface on FlexFabric 5700
I followed the instructions to split a fortyGig interface on a FlexFabric 5700 using the following guide:
using tengige
Hpe | remove preview |
| using tengige | Use using tengige to split a high bandwidth interface into multiple 10-GE breakout interfaces. Use undo using tengige to cancel the configuration. using tengige A high bandwidth interface is not split and operates as a single interface. 40-GE interface view network-admin To improve port density, reduce costs, and improve network flexibility, you can split a high bandwidth interface into multiple 10-GE breakout interfaces. | View this on Hpe > |
Now how do I get rid of the split and convert the ports back to a single 40G interface?
There is no more FortyGig 2/0/41 interface to select. So undo using tengige doesn't work
Luckily this is still in a lab envrironment.
