Unsupported cpu when trying to install ArubaOS MM on vSphere
  • 1.  Unsupported cpu when trying to install ArubaOS MM on vSphere
    Posted Feb 26, 2018 06:26 PM
    Keep getting unsupported CPU error message when trying to install ArubaOS_MM on a vsphere client, with AMD processor any ideas on workaround would be very helpful.
    Wilson.
  • 2.  RE: Unsupported cpu when trying to install ArubaOS MM on vSphere
    Posted Mar 05, 2018 03:41 PM
    Can you post the exact error? Usually it's EITHER because:
    a) the CPU is too old and doesn't support the virtualization extensions (AMD-V)
    b) AMD-V is not enabled or supported in the motherboard bios?
    What is the exact AMD CPU and Motherboard? Also what version of vSphere?
  • 3.  RE: Unsupported cpu when trying to install ArubaOS MM on vSphere
    Posted Mar 07, 2018 04:32 AM
    Error: Unsupported CPU (Intel CPU with ssse3 instruction set support required)
    Model name  AMD Turion(tm) II Neo N40L Dual-Core Processor
    press <enter> to halt the system
    is the exact error I got.
    Thanks.
  • 4.  RE: Unsupported cpu when trying to install ArubaOS MM on vSphere
    Posted Mar 07, 2018 10:43 AM
    So that CPU doesn't support VT, which is a requirement for any MM or VMC. Usually that's a laptop CPU so I would guess vmware is installed on a laptop. But either way, you need a CPU on ESX that supports VT.
  • 5.  RE: Unsupported cpu when trying to install ArubaOS MM on vSphere
    Posted Mar 08, 2018 02:49 AM
    Its micros server, I believe its enabled see attached file, Thanks.
    Attachment(s)
    docx
    MMimge.docx   200 KB 1 version
