Wired Intelligent Edge
UPDATE: Aruba CX 8320 x 4 Between two buildings
This thread has been viewed 53 times
  • 1.  UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 21, 2021 06:25 PM
    Robert Duran
  • 2.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    MVP GURU
    Posted Jan 22, 2021 03:44 AM
    Hi Robert! very interesting deployment. Out of curiosity, could you explain how the routing was planned? I mean...what was the purpose of having Bulilding 1 interconnected to Building 2 by linking the two VSX stacks considering you have on each building an Aruba 5400R zl2 taking care of routing (I expected - but I'm for sure wrong in expecting that - that the interconnection between buildings involved the Aruba 5400R zl2 and not the VSX stacks)? I'm really curious to hear about how you planned the VLANs routing and all necessary Transport VLANs between VSX and Aruba 5400R zl2 (on each building) and between buildings...Great job anyway!
    Davide Poletto
  • 3.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 22, 2021 12:59 PM
    Hi Davide,
    I will have a write up in a few days.  :-)
    Robert Duran
  • 4.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 22, 2021 08:23 AM
    Great work !
    Don't hesitate to share anonymized configuration if this is possible so that the community can have one more example.
    Vincent Giles
  • 5.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 22, 2021 01:03 PM
    Thank you, I will have the full configs available soon for the community.
    Robert Duran
  • 6.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 22, 2021 10:02 AM
    Hi Robert,
    That's a nice setup! I'm also curious about the 5406Rs. I see that you split distribution and core but on both buildings, is there a special reason for that approach?
    Having a single 5406R doing the routing on each building looks like a single point of failure, or are they stacked on VSF? I noticed both B1-CORE and B2-CORE have the same IP address, that's why I thought they may be running VSF.
    Have you considered using the 8320s to be distribution and core? That way you would benefit of VSX hitless upgrades and repurpose the 5406R.
    Anywho, good stuff!
    Cheers,
    Aarón
    Aaron Fuentes Ohnell
  • 7.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    Posted Jan 22, 2021 01:02 PM
    tgrsatgrasdfgbfsd
  • 8.  RE: UPDATE: Aruba CX 8320 x 4 Between two buildings
    MVP
    Posted Jan 22, 2021 02:07 PM
    I would love to see the config if you wouldn't mind sharing.  About to set up a very similar setup.  Reference material is always helpful!
    Phillip
    Phillip Horn
    Network and Systems Engineer
    Union College
    606-546-1650
