Hello, I would like to know what command I can use to update the controller partition, when the update file is in the flash memory of the same controller. Is it possible?Thanks
You would need to copy it upstream to an SCP, FTP or TFTP server and then copy it to the system partition.
#copy flash: filename tftp: 10.10.10.10 filename
#copy tftp: 10.10.10.10 filename system partition <0-1)
edited...
Adamc,
What version of code are you running?
cappalli,
I'm using version 5.0.4.0 and version 6.1.2.5. Thank you for the answer, I think I will use tradicional way using a SCP, FTP or TFTP server.
