Comware
  • 1.  Update Firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Posted Aug 16, 2018 03:32 PM
    Hi.
    All links related to these devices are deactivated.
    I need the equipment firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Thanks.
    #SwitchHP191024gje006a3COM5500G-EI48Port
  • 2.  RE: Update Firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Posted Aug 17, 2018 03:45 AM
    For Firmware Update on : JE006A  HP 1910-24G Switch, please refer the below link:
    https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JE006A
  • 3.  RE: Update Firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Posted Apr 22, 2021 08:09 AM
    Hi, this URL is not working anymore. Could someone point to a secure source of the latest Switch HP 1910 24G Firmware? Thanks!
    #1910
    #switch
  • 4.  RE: Update Firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Posted Apr 27, 2021 05:52 AM
    Found it, but my 3com was JE002A, works with HTTP-Upload to V1.00.10, the firmware is only 3.82 MB of size and is available in the HPE networking section:
    https://h10145.www1.hpe.com/downloads/DownloadSoftware.aspx?SoftwareReleaseUId=9673&ProductNumber=JE002A
  • 5.  RE: Update Firmware Switch HP 1910 24g (je006a) / 3COM 5500G-EI 48Port
    Posted Dec 07, 2023 11:20 AM
    The above link no longer works, does anyone know where I can find the latest firmware for the JE002A?
