Comware
Update from comware 5 to comware 7
This thread has been viewed 30 times
  • 1.  Update from comware 5 to comware 7
    Posted Feb 28, 2022 10:14 AM
    Hello Guys,
    I have to HPE HSR6602 XG and my current comware version is 5.20.106. But I have to update to HSR6602_7.10.R7809L26-RU and in manual it says:
    Before you migrate between Comware V5 and Comware V7, you must use the .btw BootWare conversion image to convert the BootWare
    So, my question is where I can find and download hardware_Bootware_V7.btw file?
    Askar Daldabay
  • 2.  RE: Update from comware 5 to comware 7
    MVP GURU
    Posted Feb 28, 2022 02:29 PM
    Hi, have a look at this software version (HSR6602_7.10.R7103-B.zip June 2015). You should be able to find what you're looking for.
    Davide Poletto
  • 3.  RE: Update from comware 5 to comware 7
    Posted Feb 28, 2022 11:21 PM
    Hi Davide, thank you for your feedback.
    I already have (HSR6602_7.10.R7809L26-RU.zip) which is the latest version as I understand. This file (HSR6602_7.10.R7809L26-RU.zip)  contains .ipe extension file, but in order to migrate from comware 5 to 7 I should upgrade BootWare and I need another file which is .btw file as I understood correctly. Now I can't find this relevant BootWare version.
    Askar Daldabay
  • 4.  RE: Update from comware 5 to comware 7
    MVP GURU
    Posted Mar 01, 2022 04:23 AM
    Hi Askar,
    I never told you to use the HSR6602 7.10 R7809, please do not insist in using that version.
    I pointed you out to use the HSR6602 7.10 R7103-B (HSR6602_7.10.R7103-B.zip).
    If you download the HSR6602_7.10.R7103-B.zip you will easily discover that it contains a folder named "HSR6602 Comware version migration", inside that folder there are these three files:
    HSR6602_Bootware_V5.btw
    HSR6602_Bootware_V7.btw
    HSR6600_HSR6800 Comware V5-V7 Migration Guide(5998-7251).pdf
    Can you check?
    Davide Poletto
  • 5.  RE: Update from comware 5 to comware 7
    Posted Mar 12, 2022 04:14 AM
    In order to migrate from comware 5 to 7 you should upgrade BootWare and I need another file which is .btw file as I understood correctly.
    Mary Houck
  • 6.  RE: Update from comware 5 to comware 7
    MVP GURU
    Posted Mar 12, 2022 07:43 AM
    Hi Mary, look above at my previous post...there you will find what you're looking for.
