update FW RAP-155 with iAP204
  • 1.  update FW RAP-155 with iAP204
    Posted May 09, 2020 06:03 PM
    i have some 204 with FW 6.5.4.16
    and have now connect one RAP-155 with 6.4.....
    When i enter the IP from the RAP i can´t Login, i think i must update to 6.5... like the 204.
    How i can do this?
    Best
    Face
  • 2.  RE: update FW RAP-155 with iAP204
    MVP EXPERT
    Posted May 11, 2020 04:02 AM
    The RAP-155 and IAP-204 use different firmware 'classes'. The RAP-155 uses 'Aries' and the IAP-204 uses 'Taurus' so depending on how these IAPs are managed there is the possibility for issues when pulling down an IAP image.
    I would suggest moving the RAP-155 to a separate VLAN from the IAP-204 , upgrading the RAP-155 to the same firmware version (e.g 6.5.x) as the IAP-204, then re-introduce the RAP-155 to the IAP-204 cluster.
  • 3.  RE: update FW RAP-155 with iAP204
    Posted May 12, 2020 04:07 PM
    Thank you, i will try.
    Maybe you know what problem ist this.
    Only the 204 are running and working
    But i see this
    Why i don´t see the AP?
  • 4.  RE: update FW RAP-155 with iAP204
    MVP EXPERT
    Posted May 13, 2020 03:57 AM
    Thats odd, you should have at least 1x AP in there! Can you try upgrading to the latest release available for the 155/204?
