Update instant AP not possible
  • 1.  Update instant AP not possible
    Posted Aug 09, 2021 10:35 AM
    Hello community,
    I want to update my (factory default) access points AP505 to latest version 8.8.0.1 from version 8.7.1.3 which is installed at the moment.
    I successfully downloaded the file from asp and tried to install the firmware via web-ui.
    When I try to upload the firmware, i only get the message
    "Status not available due to oper_id invalid or has aged out."
    I also tried another firmware (8.7.1.4 and 8.8.0.0), same problem.
    Any ideas?
    Regards
  • 2.  RE: Update instant AP not possible
    MVP EXPERT
    Posted Aug 10, 2021 03:54 AM
    Are you certain it is the right firmware version, you'll need the Gemini version of the IAP firmware. For example, the filename would be ArubaInstant_Gemini_8.6.0.10_80708
    Craig Syme
  • 3.  RE: Update instant AP not possible
    Posted Aug 10, 2021 04:07 AM
    Thanks for yours response. Yes the firmware is correct, you can see it in the screenshot
    Steffen
  • 4.  RE: Update instant AP not possible
    Posted Aug 10, 2021 05:45 AM
    see if you get the same result when you use another browser.
    if so please open a case with our Support  Centre
