UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
This thread has been viewed 104 times
  • 1.  UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted May 23, 2017 06:21 PM
    ClearPass Team,
    Please find enclosed information and details related to ClearPass and Microsoft Intune integration. In this updated TechNote read how to setup and configure ClearPass Policy Manager and Microsoft Intune Cloud-based MDM.
    In this release, we have enhanced the integration to simplify the process of collecting the necessary data from Microsoft to complete the configuration. Additionally, within this release of the extension we have added support for a new Intune attribute – Ownership. This has been requested by a number of customers and MSFT finally delivered this very recently. With this new endpoint context, we now have the ability to understand and differentiate how Intune understands a managed device, i.e. a Corporately owned device vs a Personal [BYOD] device.
    You can find the document on the support site located herehttps://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=25353
    Happy reading – go fill your boots..!!….. comments and feedback/suggestions graciously accepted.
  • 2.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jul 20, 2017 12:48 PM
    Good read, thanks for this updated technote release.
    Several questions:
    What destinations is our ClearPass cluster required to reach?
    I found the following destinations buried in an old Aruba presentation:
    Is this it? or is there other location rules that should be added?
    extensions.clearpassbeta.com
    *.docker.io
    *.cloudfront.net
    In the instruction on page 8:
    Next click on ‘API Guest Operator’ and select ‘Duplicate’. ClearPass will copy the profile and call it ‘API
    Guest Operator (2)’. Now edit and rename it to be ‘API Extension Profile’.
    There is no API Guest Operator profile present in our vanilia system install to duplicate. What is the correct profile to duplicate or listing of all profile settings needed to create a new profile.
  • 3.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Dec 21, 2017 08:42 AM
    The ClearPass InTune Integration Guide v3.0 isn't complete anymore. At least that is what I noticed when following the steps. One additional step should be added. After setting the required permissions under the app registration on page 19 you have to click “Grant Permissions” (see attachment).
    If you don't do this, ClearPass will not be able to fetch attributes from InTune.
  • 4.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Feb 14, 2018 05:43 PM
    When following the v3 tech-note guide, be careful when copy and pasting the XML Authorization Source on page 29. On page 27 the filter query is written out correctly. On page 29, although it looks correct, when you copy and paste it into XML the last hyphen (between Address and NoDelim) is missing. Do a “search” in the doc and you’ll see you only get 1 match for this: ?macAddress=%{Connection:Client-Mac-Address-NoDelim} when it appears to be in the doc twice.
    ?macAddress=%{Connection:Client-Mac-Address-NoDelim} = Correct format from page 27.
    ?macAddress=%{Connection:Client-Mac-AddressNoDelim} = Incorrect format from page 29 after copy and paste.
  • 5.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jun 13, 2018 02:52 AM
    Do you know if there is any plans for a supported End Point Context Server för Intune. In regards to microsoft's rapid development in Intune it would be nice if there was a supported, easy to use way to integrate with Intune. We are not in a situation where we can run and manage an integration via rest API. Today we have an integration with JAMF and we really like the simplicity to have a easy to use, and supported, way to manage this integration.
  • 6.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jun 13, 2018 05:38 AM
    The Intune integration does use the REST API.
  • 7.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jun 13, 2018 07:07 AM
    Well, I understand that this solution uses rest API after reding the Intune integration PDF.
    But does your answer mean that this is the only solution there will be, and i shouldn't expect in the near future see Microsoft Intune as a as a Server Type choise (like Airwatch, Mobile Iron ... )  when I try to create a new Endpoint Context Server?
  • 8.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jun 13, 2018 07:08 AM
    Correct. It uses a different integration type called an Extension. Why does the integration method matter?
  • 9.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jun 13, 2018 08:00 AM
    The integration type itself doesn't matter, but what's matter is who can give us support for an integration based in APIs that we as a customer have configured.
    Microsoft has quite alot of upgrades and what hapends if the integration doesn't work after an Intune upgrade, who should/can we call?
    And maybe the most important thing, how quickly will this kind of problem be solwed? Every authentication request will, if i understand this right, go up to Intune Cloud, not to a local DB in ClearPass like it does in the JAMF integration and what i have read also in a MobileIron integration solution. This meens that this kind of integration with Intune will be very time critical.
  • 10.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Jan 18, 2019 11:38 AM
    Very Helpful, we are currently migrating to Intune from our current MDM, will test it out. Thanks
  • 11.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Feb 07, 2022 02:16 PM
    Hello!
    Could you please share actual link (on ASP website) for this documentation?
    As far as I can see, there is still no option to integrate Microsoft Intune as a choice of server type (eg Airwatch, Mobile Iron...), correct?
    Pavlo Semenenko
  • 12.  RE: UPDATED TechNote V3: ClearPass and Microsoft Intune Extension Integration
    Posted Feb 07, 2022 02:35 PM
    Intune integration is delivered as an extension. Integration tech note is available on ASP and here:
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00112290en_us
    Mathew George
