Updates to Aruba Release Naming (Replacing ED and GA)
  • 1.  Updates to Aruba Release Naming (Replacing ED and GA)
    Posted Oct 31, 2016 01:16 PM
    In a few days, the Aruba licensing and support sites will combine with the HPE My Networking Portal.  During that switch, we are working on improving the common workflows.  It should be easier to find the releases appropriate for your controller, manage your licenses, and learn info about your devices on the new site.  One of the changes will also include updating the release tags.
    Over the years there has been a lot of confusion around the "Early Deployment (ED)" and "General Availability (GA)" tags.  These tags implied incorrect classifications and did not do an effective job indicating which release a customer should choose.  Any customer with a valid support account could download all releases with either tag.  The GA tag implied only the GA code could be freely downloaded and the ED tag gave the perception the releases were Beta code, not fully tested and not supported.
    We are updating the names to clarify the differences between the releases and make it easier to know which release to run.  GA is renamed the Conservative release.  Conservative releases are for customers who prioritize stability over new features.  Customers who only run code that has soaked in the field at hundreds of customer sites should run the Conservative release.  Releases will typically take ~3-6 months to earn the Conservative tag.  ED is renamed the Standard release with no tag associated with it.  These releases have gone through full Aruba QA testing including system, scale and regression testing and they are fully supported by Aruba TAC.
    Customers who have standardized on the GA release in the past will want to run the Conservative release going forward.
  • 2.  RE: Updates to Aruba Release Naming (Replacing ED and GA)
    Posted Nov 03, 2016 12:30 PM
    I have not had luck finding how to navagate the new HPE my networking site.  Is there a guide available describing how to find the latest Conservative or Standard release for a product line such as IAPs, controllers, etc.
    Randy
  • 3.  RE: Updates to Aruba Release Naming (Replacing ED and GA)
    Posted Nov 08, 2016 12:21 PM
    Hi Randy,
    We have had a few hiccups with moving all of the code over to the MNP.  The Aruba support site is still up for now.  If you look on the MNP site, you should search for your controller hardware.
    When you click into your specific controller, you will see two sections, current releases and previous releases.  Current releases should have the most recent patch release for all of the active trains on your controller.  Today, for a 7240, that would be:
    8.0.0.0
    6.5.0.2
    6.4.4.10 (Conservative Release)
    Previous releases will have all previous releases.
  • 4.  RE: Updates to Aruba Release Naming (Replacing ED and GA)
    Posted Feb 08, 2017 01:57 PM
    Hi Peter,
    For the Aruba 7240 (US) Controller - It looks like HPE considers the 6.5.0.2 to be a Conservative Release as of Oct 19, 2016, however Aruba's Support Site considers 6.5.0.3 to the General Availability release (and equivalent to the conservative release) as of Nov 11, 2016. I'm assuming we should be following the Aruba Support Site first based on the dates? I wanted to verify as this caused some confusion as one of my colleagues thought we were running "Early Deployment" software when he viewed the HPE website.
    Thank you for your help,
    Chris
