Updating CentOS
  • 1.  Updating CentOS
    Posted Nov 18, 2014 09:15 AM
    Fresh install of Airwave 8.0.5.  Went to run "yum update" and ran into an error.  I checked and it looks like this version is not affected by shellshock, but should another vulnerability pop up tomorrow I don't want to troubleshoot this after the fact.  Attached is the output.  Any help you can provide is appreciated.
    Attachment(s)
    txt
    output.txt   41 KB 1 version
  • 2.  RE: Updating CentOS
    Posted Nov 18, 2014 02:27 PM
    AirWave 8.0 code doesn't actively use gluster, so those packages can be removed:
    # yum remove glusterfs-libs
    After that, yum updates should resume working as expected.  Gluster packages will be used in the future with 8.1, but is safe to remove while you're still on 8.0.
  • 3.  RE: Updating CentOS
    Posted Nov 18, 2014 02:55 PM
    That worked.  Much appreciated :)
