Network Management
Updating the kernel on AirWave
  • 1.  Updating the kernel on AirWave
    Posted Mar 11, 2019 11:45 PM
    Hello Community,
    Are you able to please provide instructions on how to upgrade the kernel on AirWave's CLI?
  • 2.  RE: Updating the kernel on AirWave
    Posted Mar 12, 2019 12:42 AM
    If you are on Airwave version 8.2.4 or above, login as ampadmin. Navigate to option 7(upgrade) --> option 2(upgrade OS kernel). If there is any kernel update available this option will update it and reboot the server post update.
  • 3.  RE: Updating the kernel on AirWave
    Posted Jul 23, 2019 09:18 PM
    Is it best practice to do this before or after a AirWave version upgrade?
  • 4.  RE: Updating the kernel on AirWave
    Posted Jul 24, 2019 02:42 AM
    Kernel updates are done post upgrade.
  • 5.  RE: Updating the kernel on AirWave
    Posted Jul 24, 2019 05:13 AM
    If you have previously upgraded kernel version from AMPCLI but didnt reboot the server then it will prompt message to reboot the server before initiating upgrade.
    If latest kernel already available we can install before upgrade aswell, else need to do kernel upgrade after Airwave upgrade, if it prompts message stating latest kernel avaialble in upgrade log.
  • 6.  RE: Updating the kernel on AirWave
    Posted Jul 25, 2019 11:10 AM
    Thanks for the information!
